2hp Witte missing parts
this thread has 9 replies and has been viewed 2405 times
Old 05-27-2008, 10:16:04 PM
MarkBillesbach's Avatar
MarkBillesbach MarkBillesbach is offline
Default 2hp Witte missing parts
I started taking inventory on my 2hp Witte w/head and realized I don't have the cam gear and shaft,the exhaust pushrod,and the right mag(somebody know what it takes?)The serial# is B31368.Does any one have a exploded parts view for this engine? Thanks ,Mark
Old 05-28-2008, 08:47:26 AM
vern0n's Avatar
vern0n vern0n is offline
Default Re: 2hp Witte missing parts
Try Hit N Miss Enterprise. They will have a manual with pictures and probably have all the parts you need.
Old 05-28-2008, 09:23:55 AM
Gary Pflum's Avatar
Gary Pflum Gary Pflum is offline
Some of the Witte w/head engines were equipt with Bosch mags or Wico EK. ( Bosch being the earlier model ) If the mag bracket is still there and it has the common vertical 2-hole mag mount, it had a Wico EK.
Old 05-28-2008, 06:58:01 PM
Does the Bosch and Wico EK mags mount the same? How do I tell which is correct? Can anyone tell me what year this engine was made? Thanks, Mark
Old 05-29-2008, 12:44:41 AM
Ron Haskell's Avatar
Ron Haskell Ron Haskell is offline
My chart says it was made in 1926.
Old 05-29-2008, 08:46:13 AM
vern0n's Avatar
1926 would use a Wico EK magneto. The most sought after mag known to mankind. You can get a parts diagram from the Hit N miss enterprise catalog, (wich is free). I think they have it on thier web sight.
Old 05-29-2008, 06:53:09 PM
Thanks for the help guys,I've gotten parts from HIT&MISS int before, but I wasn't really sure of what I had. I'll give them a call. Mark
Old 05-29-2008, 07:25:25 PM
KyleBlankenship's Avatar
KyleBlankenship KyleBlankenship is offline
heres a pict. of my 2hp witte. hope this helps a little..
Old 05-29-2008, 07:42:41 PM
Kyle , Does the mag push rod screw into a ecentric on the cam gear? If so is the cam gear one piece with a cam for the exhaust and a ecentric for the mag? I've never looked at one of these up close before. Thanks, Mark
Old 05-29-2008, 10:18:48 PM
yes it does screw in to the essentric. and yes the cam is one piece.. i do believe..
Missing parts-------STOLEN! MR.22 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 10-16-2007 09:41:46 PM
Witte 8 HP. What parts am I missing?? Gasengin Hit & Miss Gas Engine Discussion 6 12-12-2006 11:01:39 AM
Missing Fairbanks Z parts Kevin Marshall Hit & Miss Gas Engine Discussion 6 12-31-2005 03:22:53 AM
I'm missing some parts??? Darryl Boyd Antique Engine Archives 4 09-07-2002 12:27:23 AM
Missing parts on Hercules 1 3/4 hp Harold H Antique Engine Archives 2 08-16-2001 10:13:54 AM
