Wisconsin Engines
Looking for some help with a Wisconsin Robin Engine
this thread has 5 replies and has been viewed 12318 times
Old 07-07-2009, 09:43:08 AM
kaptain krunch kaptain krunch is offline
Default Looking for some help with a Wisconsin Robin Engine
Well hello everyone, i came across this site while looking for some info on my wisconsin robin engine, thought it looks cool, and joined.
So heres where i need some help, i have a Wisconsin Robin EY27W, spec # 800315, 8hp(?) flathead. It has no spark, and uses an ignition system i've never heard of before called PIT (Pulser ignition transistor) system. The engine has no spark, and i have no idea how the test the two components to see which is bad, the PIT unit has 2 wires coming from it, black and red, the Pulser coil also has 2 wires, red and black. So if anyone knows how to test each one, that would be great. I have a multimeter so thats no problem. Thanks in advance!
Also, im not sure if this is considered antique, it looks fairly old, but the low oil sensor makes it seem newer? If its not, is there a better place to post it?
Old 07-07-2009, 09:45:11 AM
Default Re: Looking for some help with a Wisconsin Robin Engine
Heres the wiring diagram for the PIT ignition, seems very over engineered.
Old 07-08-2009, 08:46:15 AM
K D Redd K D Redd is offline
I have NO experience with this unit, BUT look to be an early solid-state ignition system. Also with the experience I do have with the older system, IF you can find the parts they will be VERY expensive. About the only way to test is to replace parts. You should be able to use an ohm meter to test the three coil in the diagram. The one that is connected to the spark gap, the plug, will have a high, 5 to 10 k, resistance reading.
Kent
The Following User Says Thank You to K D Redd For This Post:
Old 07-08-2009, 11:03:20 AM
I did test it, and got around 12k ohm, but thats with my cheap $10 multi meter, so it could be slightly off. I did have a feeling everything would be expensive, i'll most likely put it aside, its just too bad, the engine has great compression and is in overall good shape.
Anyone have any idea as to how old this is?
Old 07-08-2009, 09:11:40 PM
Daric J Daric J is offline
If it has low oil shut off, try disconnecting that. I ran into that on a wisc robin on a power trowel. It would run for a few seconds then cut out, like the ignition switch was shut off. Nothing like having 40 yards of concrete setting up while messing with the trowel! The correct wires pulled from the low oil shutoff unit kept it running the rest of the day, and finished the floor nicely.
Old 07-09-2009, 02:48:46 PM
Yea, i did pull the low oil sensor wires off. This engine was actually on a cement mixer at one point, the guy bought a new engine and gave me this one because it had no spark.
Robin Generator Bill Sherlock Generators & Electric Motors General Discussion 6 01-15-2019 11:49:58 AM
Robin EC10 Chris Kirk Small Air Cooled Gasoline Engines 4 10-13-2010 01:04:13 PM
Wisconsin Robin Tune-up Dan Donaldson Wisconsin Engines 6 07-24-2009 11:13:45 AM
new member welcome Robin F BDMelon Hit & Miss Gas Engine Discussion 3 07-23-2007 09:33:46 AM
Wisconsin-Robin EY27W Power curve??? Stans Wisconsin Engines 1 11-24-2005 02:17:50 AM
