Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Vertical Famous Flywheel Rotation
this thread has 3 replies and has been viewed 1764 times
Old 09-21-2009, 09:26:27 PM
Ed Kuni Ed Kuni is offline
Default Vertical Famous Flywheel Rotation
Hi, I just pulled my 3 hp Vertical Famous out of storage. I'm not familiar with verticals, can anyone tell me which way you turn the flywheels for starting? Toward the cooling tank or toward the battery box? Any help is appreciated. (This engine may be going up for sale.)
Ed Kuni
Old 09-21-2009, 09:57:39 PM
Nate S's Avatar
Nate S Nate S is offline
Default Re: Vertical Famous Flywheel Rotation
When standing on the timing gear side of the engine you will turn the flywheel in the clockwise direction.
Old 09-21-2009, 11:18:26 PM
When trying to figure rotation rmember that the exhaust valve should open at the bottom of the stroke and close at the top. If you turn it backwards it will be opening at the top and close at the bottom.
Old 09-22-2009, 12:56:45 AM
John G. Simpson
pull the top of the flywheel (either one) away from the mixer
2 HP Vertical Famous ?'s Mike Smith Hit & Miss Gas Engine Discussion 5 05-13-2013 09:26:10 PM
2 HP Famous engine rotation Bob Johnson Hit & Miss Gas Engine Discussion 2 03-20-2009 05:26:23 PM
IHC vertical 'Famous' tikiland Hit & Miss Gas Engine Discussion 5 09-23-2008 09:32:51 PM
2hp IHC vertical Famous Johnny T Hit & Miss Gas Engine Discussion 1 12-11-2007 01:06:02 AM
3hp Vertical Famous Loren Antique Engine Archives 0 02-03-2002 07:49:12 PM
