HELP! IH Cub Power Take Off
this thread has 2 replies and has been viewed 1187 times
Old 06-25-2013, 11:47:52 PM
Default HELP! IH Cub Power Take Off
I just replaced the first reverse gear in the Cub and now I can't get the power take off slider to engage with the shifter.
How in the heck do you get the shift lever in the grove on the slider ?? There is no way to see what you are doing being there is no cover or access to the inside of the differential.
I really need some advice on this one.
Thanks,
Jim
Old 06-26-2013, 09:14:57 AM
Jack Hottel Jack Hottel is offline
Default Re: HELP! IH Cub Power Take Off
Remove the transmission oil filler plug and watch through there. It's still not easy. Good luck.
Jack Hottel
The Following User Says Thank You to Jack Hottel For This Post:
Old 06-26-2013, 05:09:09 PM
EdDarowski EdDarowski is offline
As Jack said, look through the oil filler hole. A helper, with a flashlight, is handy. If you don't get in the first 5 minutes, it could take 5 hours! Stop, and try later. Ed
The Following User Says Thank You to EdDarowski For This Post:
Engines wanted to power shingle mill at Coolspring Power Museum Chris Austin Coolspring Pennsylvania 0 06-08-2010 09:58:38 PM
Old power saw Bob S Chain Saw Collectors 6 03-06-2010 11:33:17 PM
Does a Dodge Power Ram 150 have towing power? Travis Trucks, Trailers and Hauling for Shows 11 02-07-2009 09:39:46 PM
What could I use this to power? Sky Generators & Electric Motors General Discussion 5 10-21-2008 07:57:29 PM
Red Power BB Jim Gorter Antique Farm Tractors 2 02-09-2005 07:14:37 PM
