Propane Chevrolet C6500
this thread has 6 replies and has been viewed 7187 times
Old 05-20-2008, 11:59:32 AM
Alltractorman Alltractorman is offline
EMAIL NOT WORKING
Default Propane Chevrolet C6500
How would one of these trucks work for pulling a trailer? It is a 2001 C6500 with the 8.1 liter with an Allison auto in it and it runs on propane. It was an ice cream truck and the cooler was took off of it. Any word on how the engines stand up using all propane?
Old 05-20-2008, 06:45:06 PM
MoRo's Avatar
MoRo MoRo is offline
Default Re: Propane Chevrolet C6500
I'm bettin' it's an old Schwan's truck, ain't it?
I think you'll use a bit more fuel on propane, other that that, you should have no problems.
Your oil should stay cleaner longer because of the propane. You'll have to make sure you have gasoline in the fuel system when shutting down in cooler weather and start on gas, then switch to propane when the engine's warmed up.
Somebody's gonna be smarter than me and answer your question better.
Good luck!
Old 05-20-2008, 08:50:29 PM
Gerry Boose's Avatar
Gerry Boose Gerry Boose is offline
I had a 1984 Ford pickup with a 351 c.i. At 8500 km I switched it over to straight propane with a 80 gal tank in the back and put on 328,000 km with no problems. In 12 years it only failed to start once at -40. The oil stayed cleaner. Plugs lasted longer.
Old 05-20-2008, 10:07:58 PM
Mike Monnier's Avatar
Hoarder
How heavy of a trailer? The 6500 series is pretty stout compared to your average 3500 dually. Most likely it has a pretty low rear gear and will get single digit fuel mileage (5-8 mpg) driving empty.
Old 05-21-2008, 12:47:43 AM
EMAIL NOT WORKING
Yes it is a Schwans truck. I would be pulling a 25' triple axle gooseneck . We heard that if they were to be pulled really heavy the burn holes in the pistons.Most of the time we would haul 2 tractors on it, Weight total between 8000# and 12000#
The guy that has it says he drove it back from Florida and got about 8-10 MPG. He had another one piggybacked on it. Pulling a trailer he says about 7-8 MPG .We looked at it like if you can contract the fuel in the summer months you would save money at that rate over a gas or diesel pickup. It would pretty much only get used in the summer.
Old 05-21-2008, 08:44:07 PM
Clark Bigger Clark Bigger is offline
I run one its a 1994 with a 366 engine..10 foot dump body pulls 9 ton lowboy OK....no powerhouse but gets it done
Old 05-22-2008, 03:07:19 PM
few other points....has to be plugged in below 32f
I get 5.6 mpg empty & lightly loaded...load it to the limit and it goes to 3
Free 1932 Chevrolet engine Tom Kilgore Antique Autos and Trucks 1 05-26-2008 07:30:04 AM
51 chevrolet truck 25,000 miles OldAgIron Antique Autos and Trucks 7 03-06-2008 09:29:23 PM
Bad propane? Mike Helmick Hit & Miss Gas Engine Discussion 9 09-13-2005 10:18:28 AM
Propane use on W3M Arthur Onan Generators 2 05-03-2004 10:28:50 PM
