Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Antique Washing Machines
Antique Washing Machines Old collectible washing machines as used on the farm.
maytag washer id help needed..
this thread has 12 replies and has been viewed 1338 times
Old 12-25-2016, 11:13:05 PM
flathead31coupe flathead31coupe is offline
Default maytag washer id help needed..
need help with id and info on drain hose parts thanks... s/n 516316M
---------- Post added at 10:13:05 PM ---------- Previous post was at 10:05:16 PM ----------
need help with id and info on drain hose parts thanks... s/n 516316M also how do you get the brass slotted screws out under the agitator...
Old 12-26-2016, 08:30:02 PM
turbo turbo is offline
Default Re: maytag washer id help needed..
Pictures will make it easier. Not sure what washer you have??
Old 12-26-2016, 09:42:19 PM
Name:	C__Data_Users_DefApps_AppData_INTERNETEXPLORER_Temp_Saved Images_00S0S_bvNOZktAKYV_600x450[1].jpg
ID:	271106 s/n 516316M
Old 12-26-2016, 09:43:51 PM
Originally Posted by flathead31coupe View Post
Attachment 271106 s/n 516316M
sry iam not sure of the model or year thought I read and a&b model yr 1930 - 1933
Old 01-03-2017, 02:16:57 PM
Yes it looks like a Model A washer. MFG date around 1930. The model B washer is gas powered and the model A is electric like yours.
Old 01-03-2017, 03:36:56 PM
cool thanks, any idea where to get the whole drain hose and drain piece?
Old 01-03-2017, 04:53:26 PM
Not sure on the hose. One of mine needs a new hose too and I have not yet sourced any. My first place to look would be McMaster-Carr online. They carry almost every type of hose imaginable. As far as parts for the washer I think your only chance of finding any is on another washer.
Old 01-03-2017, 05:15:43 PM
Junkologist's Avatar
Images: 160
This hose may work.
http://m.ebay.com/itm/Maytag-Wringer...%257Ciid%253A1
Mike
SmokStak member #146
Old 01-03-2017, 05:51:16 PM
I did see that.....
Old 01-03-2017, 09:46:19 PM
Gregg Gregg is offline
I use 1 inch I.D. automotive heater hose from my local auto store. About 21 inches will work. It is a little more pliable and works perfect. Just cut the ends off your old hose and use cold weld to fasten the drain hose end back on.
Early Maytag Wooden Tub Maytag Washer Shelby Babcock Antique Washing Machines 16 12-30-2014 11:13:53 PM
Maytag washer RJ59 Antique Washing Machines 1 01-02-2014 08:30:49 PM
Maytag Early Model 82 Washer Info Needed Geoff V Antique Washing Machines 13 02-05-2013 04:18:27 AM
Maytag Washer John in Maryland Antique Washing Machines 3 07-05-2012 02:29:36 PM
Maytag Washer J2L Reinholdt Antique Washing Machines 1 08-05-2008 05:47:56 PM
