Avery Plow Guide
this thread has 10 replies and has been viewed 1188 times
Old 06-24-2018, 03:50:02 PM
Matthew Guy Clarke Matthew Guy Clarke is offline
Default Avery Plow Guide
Down here at Marland Travis sale trying to keep things out of the junk I bought this from one of the junkers. Marland had said it was a plow quide for a big tractor. Opinions ?
ID:	312991   Click image for larger version
ID:	312992   Click image for larger version
The Following 3 Users Say Thank You to Matthew Guy Clarke For This Post:
Old 06-24-2018, 07:38:37 PM
TSeaberg TSeaberg is offline
Default Re: Avery Plow guide
I would guess it’s more of a disc plow vs plow guide
The Following User Says Thank You to TSeaberg For This Post:
Old 06-24-2018, 09:48:44 PM
A disc plow would be way heavier and all cast. Also look at the way the scraperis oriented as it rotates. It is certainly something to ponder as to whether that would keep any prairie tractor on track. Maybe a smaller tractor?
For reference, here's a Howard disc plow on a Massey video.
Howard disc plow
Old 06-26-2018, 01:58:41 PM
oldironlindy oldironlindy is offline
I THINK IT IS A FARMALL CUB BELLY MOUNT DISK PLOW.
https://www.youtube.com/watch?v=TH48HD7rhVU
The Following User Says Thank You to oldironlindy For This Post:
Old 06-26-2018, 03:26:02 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
I think it's a disc plow alright, but the mounting is different than the cub. Maybe for Allis CA?
Old 06-27-2018, 04:27:27 PM
Howard disc plow
I remember now, the story was, it hooked to the steering and followed the furrow as the plows were platforms with men on them.
Old 06-27-2018, 10:58:38 PM
Default Re: Avery Plow Guide
Yes, but they usually use heavy cast wheels that didn't look like discs for plow guides. I haven't ever seen an Allis undermount disc plow.
Old 06-27-2018, 11:56:36 PM
halcon halcon is offline
It is not off something extremely old as I see the brackets are welded on that pipe.
Old 06-28-2018, 12:29:58 PM
I missed seeing Lindy and FWorth it sure does resemble the Cub Disk Plow. I agree, or maybe Allis. I saved it from the junk man. It may be seen at LeSuer in 2019.
Old 06-28-2018, 12:35:51 PM
BMyrkle's Avatar
BMyrkle BMyrkle is offline
Images: 40
When you see pictures like this, it's very easy to see why someone might think this is a plow guide.
IHC Mogul Plow Guide Harry Henderson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 11-13-2018 03:32:36 PM
Need Help to Identify a Plow Guide lukeste Farm + Industrial Antiques and Collectibles 0 02-09-2018 10:48:36 AM
Early Plow Guide Steering Device on Fordson and Case? Nik M Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 05-03-2017 09:20:37 AM
Plow Guide for Titan 10-20 SproutW Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 06-24-2012 06:27:29 AM
international 8-16 plow guide parts mrkimball Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 10-14-2011 10:44:13 PM
