Spark Advance on an Oilpull
this thread has 4 replies and has been viewed 789 times
Old 07-15-2018, 11:43:20 AM
Wayne Riedlinger Wayne Riedlinger is offline
Default Spark Advance on an Oilpull
Im wondering about the correct way to set the pionts on a 20-40 G oilpull. When timing the points is the spark advance leaver in the back retarded position or should the points be set with the leaver in forward position. Ive always did it with the leaver forward. Just wondering how other guys are doing it. It has the DU 2 mag on it.
The Following User Says Thank You to Wayne Riedlinger For This Post:
Old 07-15-2018, 06:08:33 PM
Randy Kvill Randy Kvill is offline
Default Re: Spark Advance on an Oilpull
Manuals usually refer to retarded spark. I always set with full retard.
The Following 2 Users Say Thank You to Randy Kvill For This Post:
Old 07-15-2018, 09:22:39 PM
Set points with the follower on the high portion of the magneto cam regardless of lever position. Lever position and timing is another matter but make sure firing is past dead center when retarded before cranking to start.
The Following 6 Users Say Thank You to Oilpulled For This Post:
Old 07-15-2018, 10:59:32 PM
halcon halcon is offline
Wayne the most important thing is that the impulse should trip slightly past dead centre, say about 2" on the OD of the fly wheel. then the running timing will look after it self so you can set the running timing with the lever according to it's performance.
The Following 6 Users Say Thank You to halcon For This Post:
Old 07-28-2018, 09:55:37 AM
Well I had a chance to play with the rumley yesterday, been gone working quite a bit lately. I set the timing about 2 inches past D/C. On the flywheel and the points just starting to come onto the rub block with the leaver in retard position.Starts first pull over compression on #1.
The Following 5 Users Say Thank You to Wayne Riedlinger For This Post:
Spark advance burnhambill Magnetos, Ignition Coils and Spark Plugs 10 06-07-2013 06:52:55 PM
Rumely Advance Oilpull Factory Photos ~VERY COOL~ signchaser Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 29 02-08-2010 02:03:15 AM
McC 6 hp M spark advance caseyvand Antique Gas Engine Discussion 2 09-08-2009 09:21:15 AM
Advance Spark Arrestor Gary K Steam Stationary Engines, Traction Engines, Steam Boats 1 07-29-2006 08:56:10 PM
WITTE SPARK ADVANCE Kevin Leibensperger Antique Engine Archives 1 03-25-2002 06:55:53 AM
