Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment
Vintage Construction Equipment Graders, Shovels, Fork lifts, Dozers & Crawlers, Pay loaders & Fork lifts
R G LeTourneau Rear Double Drum Power Control Unit
this thread has 12 replies and has been viewed 2457 times
Old 07-03-2017, 11:52:56 PM
Default Re: R G LeTourneau RDDPCU
Did unearth two copies of the Wauk-Hesselman manuals, spoken for above; if any more turn up (unlikely) will post in the Antq Auto/Truck forum.
The Following 2 Users Say Thank You to Bud Tierney For This Post:
Old 11-12-2017, 01:19:42 PM
halcon halcon is offline
Thank you very much Bud, that little Waukesha manual is proving to be very valuable to us as the Hesselman components are nearly identical. In fact there is a plate riveted on the injection pump bracket explaining that the Allis Chalmers engine is built under Waukesha's licencing agreement with Hesselman.
Old 03-26-2018, 11:16:35 PM
Kelly Tytlandsvik Kelly Tytlandsvik is offline
Images: 407
Default Re: R G LeTourneau Rear Double Drum Power Control Unit
Check lugs and Cleats forum for pictures and video of this tractor running. look for trip to Clyde Halls.
The Following User Says Thank You to Kelly Tytlandsvik For This Post:
MEP002A Control Unit Assmbly Mariner Onan Generators 3 12-28-2015 09:25:21 PM
Very Old Moisture Control Unit Information Needed Sherwood Farm + Industrial Antiques and Collectibles 1 07-27-2014 12:11:11 PM
MEP-903C control unit & connect harness mrhaugen Military MEP and Aircraft Gen-Sets 0 01-06-2012 03:51:24 PM
No voltage control old 30kw unit Alan Burger Onan Generators 16 01-05-2010 10:54:15 AM
Kohler 3A22 w/Cutler-Hammer Control Unit Manual(s) ? Ross Hunt Kohler Generators 3 06-10-2008 08:37:06 AM
