Vintage Construction Equipment Graders, Shovels, Fork lifts, Dozers & Crawlers, Pay loaders & Fork lifts
Aircraft tug Id
this thread has 30 replies and has been viewed 4670 times
Old 10-30-2016, 11:19:08 PM
machinist58 machinist58 is offline
Default Re: Aircraft tug Id
When I was getting mine going my son had a wrecked '75 Plymouth Duster with a 400 big block in it. The thought crossed my mind several, maybe more, probably more, times. He and I snatched the tired slant out and wedged that big motor in. We put a ton of work and time into that Duster just to have some stoned kid rear end it a few weeks after we got it on the road. It was a sweet ride.
Cheers!
Terry
The Following User Says Thank You to machinist58 For This Post:
Old 10-31-2016, 06:53:57 AM
E27N's Avatar
E27N E27N is offline
Originally Posted by ozfarm View Post
sandblast ,repaint
set of flames
twin system
and lower the front
Well you're 2/5 ths correct......
This post brought to you by Lucas ele
Old 10-31-2016, 04:34:44 PM
Lordy, I haven't painted a set of flames since high school (1976)! I suppose the thing would look rather dashing with a set on it's flanks!
As for exhaust I had run it out the back with a turbo muffer. One day while attempting to get the thing out of the mud, they sink quite dramatically, I found a buried bag of hardened concrete with that shiny new muffler. Now it just comes out the down pipe, not loud at all but has a sexy moan as you bump it up through the RPM's.
Remember what I said about the mud. 3 hours of cribbing and jacking with a high lift jack sets an indelible message in your mind............
Cheers!
Terry
  #24
Old 10-31-2016, 07:39:19 PM
E27N's Avatar
Ozfarm has been winding me up for weeks about hotrodding the tug, hence the groan......... mine has a small muffler on it and has a nice note to it, I'm going to leave it since I want to use it at our club in town and overly loud would get old fast. As for bogging it..... I think I'll pass using it as a tractor.......
Old 10-31-2016, 10:05:29 PM
ozfarm ozfarm is offline
i gotta couple of 318 truck engines
we could build one of them into something sweet
set of chrome stacks
possibilities are endless
The Following User Groaned at This Post:
  #26
Old 11-01-2016, 01:11:43 AM
Oz, it looks as if a 318 would fit just fine. Maybe some problems with distributor clearance but nothing a torch and grinder wouldn't fix. Everything on the machine is 1/4" or thicker. The exception is the hood panels. The side panels can be left off making room for tghose stacks on reversed manifolds.......I had a crazy huge pair of racing slicks given to me for reasons I can't remember. It was terrible tempting to build some wheels up and stuff those babies under there for tractor shows and such. My friend has several more of these from different manufacturers, some with cabs, some ranging up to 20,000lbs. I have pictures of his 10,000lb tug sitting beside mine. Let me see if I can remember how to post pics.......
Cheers!
Terry
---------- Post added at 01:03:44 AM ---------- Previous post was at 12:03:57 AM ----------
My tug next to my friend's 10,000 tug. Here mine is all decked out in chains and a tire on the blade for pushing cars.
Cheers!
Terry
---------- Post added at 01:11:43 AM ---------- Previous post was at 01:03:44 AM ----------
Crap! That didn't work! The pictures are on my flickr page here: https://www.flickr.com/photos/studebaker-terry/
Well!
Cheers!
Terry
Old 11-01-2016, 06:43:02 AM
E27N's Avatar
The next one we find you can go wild with...
Old 11-20-2016, 10:21:38 PM
I fired up my tug (BIG UGLY) for the first time in a month. The outside temp was 34f with a 20 mph wind howling from the mountains up north. Pulled the air cleaner off, put my hand over the carb and three turns over it was running! The old beastie is a notoriously hard starter below 40 so you could have knocked me over with a feather!
Not complaining though..........
Terry
The Following 2 Users Say Thank You to machinist58 For This Post:
  #29
Old 11-21-2016, 11:01:45 AM
E27N's Avatar
Mine has a particular way it likes the be started cold , choke out, turn key and it fires and stops, choke in, pump throttle twice, then hold it flat and it will start in a few turns.
Old 11-23-2016, 06:52:10 PM
[QUOTE=E27N;1336518 OURS has a particular way it likes the be started cold , choke out, turn key and it fires and stops, choke in, pump throttle twice, then hold it flat and it will start in a few turns.[/QUOTE]
Aircraft Turbosupercharger Heins Blacksmithing and Metallurgy 32 06-14-2014 10:48:54 AM
GE Aircraft Generator Horse Power at 511 Generators & Electric Motors General Discussion 3 11-07-2010 04:02:34 PM
Aircraft Generator catdoo Military MEP and Aircraft Gen-Sets 14 06-01-2010 11:09:21 PM
aircraft engine Robert Johnson Antique Engine Archives 7 02-22-2001 02:36:39 AM
