Go Back   SmokStak > SmokStak® General Discussion > The Junque Drawer
The Junque Drawer Excess tools, parts or books that might be rare and that someone else might need. This is NOT a buy and sell forum.
The Junque Drawer
Noisy air blowers
this thread has 19 replies and has been viewed 1607 times
Old 01-31-2016, 07:38:04 PM
Default Noisy air blowers
Allright I put this in LeJunque drawer as it seems appropriate. Junk is what I'm dealing with here
I have a fairly large fireplace that has two blowers under the hearth. These push air upwards around the steel firebox and the heated air comes out louvers at the top for splendid heating action.
To make a short story long as I usually do, and where better than the stak to sak a question, after 40 years these 1/20th hp blower motors ala Grainger are worn out and noisy. Me being tricky and resourceful yet a cheap ass bought two new motors at $30 each instead of new blowers at $132 each.
Oh boy here's my new motors thankyouverymuch Mr. Mailman.
Oh oh,, China.
I hook one up and it vibrates like mad.
Grrrr. I take them apart and balance the armatures and now they're pretty smooth. The windings were also very loose so I varnished them to firm them up. Thanks Beijing.....
I put them back in the fireplace and they're noisier than the worn out ones.
Needless to say me not pleased.
Anyone have a suggestion for some sound deadening foam I can coat the blowers and housings with? The stuff used for cars is horribly overpriced.
Old 01-31-2016, 07:45:49 PM
Glenn Ayers Glenn Ayers is offline
Default Re: Noisy air blowers
Can you mount the motors in rubber grommets ?
Did some tin or something come loose & is now making noise from motor vibration ?
"I'll have the Red Pill, thank you."
Old 01-31-2016, 07:46:55 PM
Amax Amax is offline
Spray foam? Fiberglass wool?
Maybe don't mount the fans down tight - let them wiggle a bit - maybe orings under the mounts to sound isolate them.
Old 01-31-2016, 08:55:30 PM
The blowers are rigidly mounted to a pre made framework which is attached to the masonry. So there is no practical way to float/isolate them. Besides. it's essentially a press fit in the enclosure and no room to float them. So at this point I'm looking to mitigate the noise.
There is a decent gap from the blower to the decorative grille. I'm thinking of putting a sheet of thin plywood in there to redirect the noise inwards yet not restrict airflow to the blower. Coat this with sound foam also. Temperature isn't an issue as they're at floor level pulling cold air in.
Crappy cell phone pic.
Old 01-31-2016, 09:11:11 PM
What held the blowers in were four 1/4-20 bolts to the pre made support enclosure. These assemblies were put in, then the masonry was installed around them. Getting them out was a nightmare as I had to go at the inside bolts by feel. Then the blowers wouldn't come out as they're such a tight fit. I had to cut the bottom of the lip on the enclosure to get them out!
There is really no way to put the 1/4-20's back in on the discharge so I made an angle iron support to hold them. Quite rigid and a perfect air seal. But yes, very rigid...
ID:	245255   Click image for larger version
ID:	245256   Click image for larger version
Old 01-31-2016, 10:20:32 PM
Get a Variac and run them at 95% voltage. Air flow will be almost as much and you can find a sweet spot noise-wise. (Assuming they are brushed motors, not synchronous.)
Old 01-31-2016, 10:45:25 PM
Shaded pole.
Old 01-31-2016, 11:03:01 PM
I'm out of ideas. Looks like everything is stacked against you and you have pretty much already thought of everything.
Old 01-31-2016, 11:12:58 PM
Thinking the Home depot sticky back duct noise stuff.
Old 01-31-2016, 11:23:03 PM
Greg Mosley Greg Mosley is offline
Just a thought. When you had the squirrels out did you wash them. The sails in the fan have a tendency to fill with debris from years of use. Throw them in a tub of warm water with a bit of dish soap and let them soak. Then hose them off. Be very careful not to disturb the balance clips or remove or move them that are attached on the blades. If you do, Good Luck. If any bending of the fan occurred during removal they will Never run smooth again. This should help you immensely. Enuf Said
How noisy is an Onan 6.0 DJB tdarden Onan Generators 22 04-30-2014 07:34:15 PM
Anyone have any Vintage Lawnboy Mowers/Blowers that they would sell and ship? smokey honda Garden Tractors / Mowers / Scooters 12 11-26-2013 10:13:38 PM
Noisy! Rod Fielder Oil Field Engines & Related Equipment 3 09-29-2011 02:59:45 AM
New Way Noisy Valve Tom Herd Antique Gas Engine Discussion 5 11-29-2009 08:41:54 PM
Noisy Gears Jim Tremble Antique Engine Archives 25 01-24-2003 10:49:46 PM
