Hot Air Engines
Gas-fired DeLamater Ericsson in action
this thread has 6 replies and has been viewed 1986 times
Old 09-02-2017, 01:00:10 PM
Brent Rowell Brent Rowell is offline
Default Gas-fired DeLamater Ericsson in action
Just finished a "reconditioning" of this engine. I won't call it restoration since I only needed to add the air chambers, rebuild the pump and get a new piston leather. It is nearly as nice as when it left DeLamater Iron Works in New York City in the late 1880s-early 1890s: no wear in any of the bearings and runs as quiet as a mouse, or at least as a rat. The first DeLamaters from the early 1880s had a simple cylindrical pump, shorter water jacket, lighter flywheel, and thinner, weaker linkages. The improved version got a new pump designed by Thomas Rider (son of Rider engine inventor A.K. Rider), beefier linkages and a heavier flywheel. Thomas Rider, in charge of all hot air engine production at DeLamater at the time, also patented an inner sleeve used inside the hot cylinder to increase efficiency.
Here's the video:
Old 09-02-2017, 06:06:27 PM
Default Re: Gas-fired DeLamater Ericsson in action
That sure runs great Brent.
Old 09-17-2017, 08:31:16 PM
Gil Garceau Gil Garceau is offline
Sure does run great even after 125 years!
My youtube channel: http://www.youtube.com/user/reddrryder/videos
The Following User Says Thank You to Gil Garceau For This Post:
Old 11-27-2017, 07:21:31 AM
colo colo is offline
Hi Brent,
why is this not present in Rider-Ericsson engines like mine?
Old 11-27-2017, 09:18:40 AM
Vinny Cavaliere's Avatar
Vinny Cavaliere Vinny Cavaliere is offline
Brent
Another beauty you brought back.
Vinny
The Following User Says Thank You to Vinny Cavaliere For This Post:
Old 11-27-2017, 10:21:31 AM
Davide,
I don't know the answer to your question. The inner sleeve was patented by Thomas Rider when he worked at DeLamater Iron Works but was apparently not used later when DeLamater became part of Rider-Ericssson. Thomas did not join the new company but I assume the company owned his patents.
The Following User Says Thank You to Brent Rowell For This Post:
Old 12-02-2017, 02:33:58 PM
Hi Brent,
it would be interesting if you opened two new threads:
DIFFERENCES between the various RIDER pumpers manufacturers
DIFFERENCES between the various ERICSSON pumpers manufacturers
what do you think about it?
Best Regards
Davide
Here's peta in action Kpack Onan Generators 25 10-11-2014 11:06:45 PM
Another BFA back in action TWortmann Onan Generators 5 02-05-2009 08:18:32 PM
Help with course of action for JD rebuild Gilbert_Bates Antique Gas Engine Discussion 4 08-29-2006 09:37:17 PM
Holt 120 in action Steamrguy Antique Engine Archives 0 11-29-2004 01:15:24 PM
