Hot Air Engines
Stirling Cycle Quiz
this thread has 7 replies and has been viewed 876 times
Old 04-01-2018, 03:46:12 PM
Brent Rowell Brent Rowell is offline
Default Stirling Cycle Quiz
This section of the forum tends to get stale so here's a little quiz for you: What's the most common commercial use of the stirling cycle nowadays?
The Following User Says Thank You to Brent Rowell For This Post:
Old 04-01-2018, 04:58:36 PM
John Newman, Jr.'s Avatar
Default Re: Stirling Cycle Quiz
Refrigeration or heating.
When driven by a motor, the hot cap will get either quite hot or cold, depending on direction of rotation.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
The Following 2 Users Say Thank You to John Newman, Jr. For This Post:
Old 04-02-2018, 10:26:35 PM
Well John, you're at least half right. When you apply power to a stirling engine to run the normal cycle in reverse (power piston now leads the displacer by 90 degrees), the exposed cylinder (which is normally heated) now removes heat from the air around it. Please don't ask me how this works. These stirling 'cryocoolers' and are now used by the thousands in aerospace, defence, medicine, and science. They will cool down to extremely low temperatures: stirling freezers routinely keep temps at 100 below zero and can even reach much lower temps required for superconductivity. They have few moving parts, are maintenance free, don't use refrigerants, and are nearly silent.
The Following 11 Users Say Thank You to Brent Rowell For This Post:
Old 04-03-2018, 12:51:40 PM
Exclamation Re: Stirling Cycle Quiz
They are used in oxygen production as well. Some of your portable battery powered medical oxygen concentrators use them!
Old 04-03-2018, 05:34:50 PM
Barnbikes Barnbikes is offline
Most common noncommercial use of the stirling cycle engines nowadays?
Paper weights and dust collectors.
The Following User Says Thank You to Barnbikes For This Post:
Old 04-03-2018, 05:58:30 PM
Please send me all your unwanted stirling engine paperweights and dust collectors.
The Following 2 Users Say Thank You to Brent Rowell For This Post:
Old 04-07-2018, 08:49:25 AM
ChipTosser ChipTosser is offline
I'm closer, to ship to. I'd even pay for the shipping!
Old 04-07-2018, 12:14:21 PM
Marv in Minn's Avatar
Marv in Minn Marv in Minn is offline
i'll come pick them up
restoring old iron, hot air engines and modelmaker.
The Following User Says Thank You to Marv in Minn For This Post:
brayton and ericsson cycle engines not stirling cycle.. imotorhead64 YouTube Old Iron Videos 0 02-12-2013 09:29:13 AM
Hot Air / Stirling Cycle Engines Peter Hot Air Engines 6 05-07-2009 08:42:48 AM
POP QUIZ Gus Simms Generators & Electric Motors General Discussion 7 01-26-2004 09:54:41 PM
IHC quiz David Greenwalt Antique Engine Archives 8 02-20-2003 03:14:04 PM
Stirling cycle & deep space exploration mbh Antique Engine Archives 0 02-15-2003 11:06:23 AM
