Hot Air Engines
Erricson Engine Pump Parts Question
this thread has 3 replies and has been viewed 677 times
Old 07-13-2018, 05:13:41 PM
Question Erricson Engine Pump Parts Question
Does anyone have a parts diagram for an Ericson engine? Our engine club has had a 5" engine donated to us. It was a pile of parts! It has now been assembled, but we need to know how the lower (inlet) check assembly was put together for the water pump. The spring is rusted to bits, and we only have a few pieces of the check. Please help! It apparently was built 1906-7 from the design - single cylinder with the displacer down the center. the original tag is long gone, is there another place the engine S/n might be found? This is a locally used engine (Sussex County NJ), and we would like to get it running again. Is anyone making replacement parts for the engine mounted pump? Thanks!
Andrew
Old 07-13-2018, 06:16:50 PM
Brent Rowell Brent Rowell is offline
Default Re: Erricson Engine Pump Parts Question
There are some cutaway views of some of the Ericsson pumps in the old catalog reprints, but there were several variations in the pumps, so would need to know which type it is. How did you determine the date? Hard to know even with the serial no. If you can find the number I can give you an idea. They were often stamped into the top of the cylinder in addition to the nameplate--hope you can find it. Don't know of anyone making pump parts although Don Worley might have something or be able to make it--but I think you're already in touch with him.
Old 07-14-2018, 06:41:14 AM
Marv in Minn's Avatar
Marv in Minn Marv in Minn is offline
Originally Posted by Andrew Mackey View Post
Does anyone have a parts diagram for an Ericson engine? --- Is anyone making replacement parts for the engine mounted pump? Thanks!
Andrew
i sent you an e-mail, Marv
restoring old iron, hot air engines and modelmaker.
Old 07-25-2018, 03:51:24 PM
colo colo is offline
Hi Andrew,
this is my pump:
Originally Posted by colo View Post
Today I practically finished the job. Only the water pipes are missing.
But for today, be satisfied with the photos of the pump
Senza titolo by Davide Coloretti, su Flickr
https://www.smokstak.com/forum/showt...33#post1442833
The Following User Says Thank You to colo For This Post:
Fuller Johnson Pump Jack Engine Parts Help Jim Alexander Antique Gas Engine Discussion 0 07-03-2014 03:12:14 PM
Auxiliary Parts for IHC LB Engine with Vacuum Pump? kpowl Antique Gas Engine Discussion 1 08-14-2013 10:34:05 AM
International Engine Piston Water Pump Parts ID. Please. ShaneZahn Unidentified Engines 2 01-06-2013 01:50:17 PM
Fuller Pump Engine Parts? JKWidener Antique Gas Engine Discussion 2 03-30-2010 07:17:41 PM
Parts for Fuller & Johnson pump engine Russell P. Antique Gas Engine Discussion 2 03-23-2007 08:10:20 AM
