Kohler Generators Restoring, maintaining and operating vintage Kohler generators. |
Newer Kohler standby problems....this thread has 11 replies and has been viewed 354 times
Thanks for the advice. The owner, the lineman installed it. There are several things I'd love to address some day. When its warmer..
Sponsored Links |
IIRC those rocker switches are known to fail somewhat frequently. I think they get bugs and moisture inside. Check for voltage as suggested. Bat + on the center terminal and then out on the other two. The start wires should not make any difference. It should run without anything connected except fuel and battery.
The Following User Says Thank You to Mark Dieckmann For This Post:
Bookmarks |
Thread Tools | |
Display Modes | |
Generac vs Kohler 20kw+ Standby Generator | GeneratorNewb | Generators & Electric Motors General Discussion | 49 | 03-08-2018 11:09:58 AM |
Help with newer Kohler motor interchangability? | 1936JDB | Small Air Cooled Gasoline Engines | 2 | 10-01-2016 10:44:29 AM |
Kohler Diesel 10ROY Standby Generator & Thomson Automatic Transfer Switch & Boyd Tank | TC25D | Kohler Generators | 3 | 01-01-2014 06:34:25 PM |
Kohler with Problems | acarguy44 | Kohler Generators | 1 | 04-20-2011 08:27:22 PM |
Kohler 35 Kw Standby Barber Colman Actuator | Descentman | Kohler Generators | 3 | 06-02-2010 08:57:42 AM |
