Kohler Generators
10KW Kohler generator
this thread has 4 replies and has been viewed 445 times
Old 12-14-2018, 06:57:57 PM
Pak7819 Pak7819 is offline
Default 10KW Kohler generator
Gentleman,
I have a lead on a 10KW Kohler generator powered by a 3cyl John Deere diesel engine. Would this be the correct place to ask questions provided I can acquire a better image of the model or serial number of the generator? Attached pic is all i have at the moment and its not 100% legible. Looking for documentation such as manuals to confirm its specs.
Its not a light tower as the forum calls for,...which is my reason for asking.
Thanks,
Paul
Old 12-14-2018, 07:08:25 PM
Viking66 Viking66 is offline
Default Re: 10KW Kohler generator
Does it run and produce power?
Those would be first 2 questions I would ask the seller, and then make him demonstrate that it does.
Not much documentation out there for any Kohler Gensets, but you may get lucky and someone here might have something.
Get a better pic of that TAG, it is the one you need for gaining information. See if you can get more pics of the entire setup.
As Always....This Place is Awesome!!!!
Old 12-14-2018, 10:47:51 PM
Zephyr7 Zephyr7 is offline
Yep, this is the place to and about Kohler generator stuff. There are many knowledgeable people here.
If you try a Kohler dealer, you may be able to order manuals. This is probably a question for the dealers service department, but maybe sales. Iíve ordered manuals for older generators before, but they arenít cheap.
I can say that Iíd love to get a small diesel set around the 7.5-10kw range. Thatís a great size to both run a good house load, and also get good fuel economy. Make sure the set runs before you buy it. If it doesnít run, itís a gamble, so try to get it for scrap value or something close to that.
Bill
Old 12-15-2018, 09:31:12 AM
Mark Dieckmann Mark Dieckmann is offline
Thanks,
Paul
The "Light Plant" the forum title refers to would be the old DC gensets from the 20's - 30's that were used in rural areas before rural electrification. We cuss and discuss anything Kohler built here though, so ask away. I would agree with everything you have been told so far. Welcome aboard.
Old 01-31-2019, 03:51:46 PM
BrianHaze BrianHaze is offline
Rcop originally came with perkins engines, not john deer. After guessing about the spec number number, tp-1018 kohler part manual.
Kohler 10KW generator Model 10CCE61 Dirtboy170 Kohler Generators 2 03-22-2017 06:13:30 AM
Waukesha Kohler gen set 10kw YellowLister Kohler Generators 55 03-27-2016 06:22:08 PM
Kohler 10kw McCormickDeering22_36 Kohler Generators 0 03-02-2010 08:34:25 PM
Re: Help with Kohler 10KW Gene O. Carpenter72 Kohler Generators 8 09-02-2004 08:53:32 PM
