Kohler Generators Restoring, maintaining and operating vintage Kohler generators. |
Kohler model D with no genset bitsthis thread has 17 replies and has been viewed 546 times
I tried a lot of plugs. Had trouble with fouling. Finally learned that the model A ford used the same plug so I joined a model A forum and found they all agree, NGK A-6
I know, it's a resistor plug. I have used them for 4 years about 6 shows a year. They work great. |
Sponsored Links |
I've used Champion J-21 plugs exclusively for the last 39 years with excellent success. No fouling whatsoever.
![]() Quote:
Aren't all the Champion J series spark plugs 14mm thread? Cheers Scott |
Scott, you're correct. They're D21.
Dang brain fog! |
Looking at your pics Scotty, looks like there is a flywheel hiding in there below the radiator. Looks also like somebody has built a frame with a ball bearing mount on end of what would be shaft running through armature. That would partially aleviate the side loading issue, though I likewise agree that an inline power takeoff would be better. Something like a "lovejoy" coupling.
Doc
Beginning anew http://machinebuildersnetwork.com |
G'day Scotty,I finally managed to have mine follow me home tonight.
The crank handle,gen shroud and control box surfaced while moving it out of the junk and long grass. |
![]() Quote:
Bill |
I believe you are right Bill.
I think for me it might be something I can enjoy by messing around getting the motor running?From there I am very happy to have found the control box and the other bits. If I can manage to get it running I would tidy up the appearance of the missing parts and fit them back to the set to complete it's appearance. I know how to get spark out of a magneto,but after that I have zero knowledge of the generator part,and I also lack the desire to learn. I would be very happy however to be able to present the set as complete,and that way I have saved it from the elements,from further damage or misplacement of those important parts. The next owner might have a better fighting chance of getting it right if I treat it that way? Scotty will be along shortly to scold me for pinching his thread ![]() ![]() |
Bookmarks |
Thread Tools | |
Display Modes | |
wacker/kohler 180 Hz 240v genset (HGG)kohler | miraclewhip | Kohler Generators | 17 | 01-30-2019 12:27:09 PM |
1925 Kohler Model D Genset | TomFG | Kohler Generators | 35 | 03-03-2014 09:34:38 PM |
KOHLER, model 4.5CM21 RV GENSET NEED INFO | 3kohlers | Kohler Generators | 1 | 01-12-2010 08:08:40 PM |
My first Kohler Genset | Meco3hp | Kohler Generators | 11 | 09-17-2006 04:13:16 PM |
Kohler genset help please | Rogeralan | Kohler Generators | 4 | 06-20-2006 11:17:21 PM |
