Go Back   SmokStak > SmokStak® Antique Engine Community > Hot Air Engines
Hot Air Engines Stirling engines, Rider-Ericsson and others.
Hot Air Engines
Amberg Gasmaschinenfabrik - Stirling Engine
this thread has 25 replies and has been viewed 8981 times
Old 06-23-2018, 07:56:26 AM
Brent Rowell Brent Rowell is offline
Default Re: Amberg Gasmaschinenfabrik - stirling engine
I sent you an email regarding exactly which piece you need to measure. Did you receive it?
Old 06-26-2018, 02:13:37 AM
Todor1968 Todor1968 is offline
Default Re: Amberg Gasmaschinenfabrik - Stirling Engine
Hello, I'm taking pictures. I'm going to use this part and I need information about the distance between the two holes. Thanks for your cooperation!
ID:	313073   Click image for larger version
ID:	313074   Click image for larger version
Old 06-27-2018, 11:58:28 AM
stirlingmaier stirlingmaier is offline
Hi Davide,
checking my upgraded homepage www.stirlingmaier.com you will find out that the button "booklets" doesn't exist any longer. Because the booklets are almost sold out. As is the "Amberg" booklet. But the whole report is still
existing, of course. It will be published in improved and extended form in (digital) volume "compendium 10" scheduled for 2021. Including all images as big-size pictures and in full color. Perfect for restoring an engine to former original paint.
If you cannot wait till "comp-10" is available - at the moment I'm finishing
"comp-07B", the comprehensive report about Hubertus Raab and his hot-air engines - just send an email: hot-air-maier@t-online.de.
Good luck in restoring. Gerd
Old 06-27-2018, 10:22:41 PM
In response to Todor1968, I remove the part and make the measurement for you tomorrow.
Old 06-28-2018, 07:55:47 PM
The distance between the two holes in your drawing is 152 mm.
Old 09-25-2018, 11:00:34 AM
Thanks so much about the given information. I was very busy the past 2 months traveling, so i was unable to reply. Thanks so much again, i'm expecting results soon. I'll post and update with some photos when im done.
Amberg Engine collector visiting CA Thiel Hot Air Engines 0 12-10-2016 03:26:28 PM
Vertical Amberg hot air engine Brent Rowell Hot Air Engines 3 08-01-2016 01:04:39 PM
Stirling Engine Stacy Leis Hot Air Engines 5 09-18-2010 05:01:21 PM
Stirling engine, HELP! ssimntih Scale Model Engineering 4 10-07-2009 01:47:35 AM
Amberg Engine Ed Dina Antique Engine Archives 0 01-17-2003 05:43:31 PM
