Kohler Generators
Kohler Regulator, B-258545, Light Board GM34505
this thread has 5 replies and has been viewed 1731 times
Old 12-04-2015, 03:44:55 PM
BrianHaze BrianHaze is offline
Default Kohler Regulator, B-258545, Light Board GM34505
Flightsystems is looking for these two components. These are the scr pack with heat sink, also called the heat sink assembly. The other is the light receiver board for the regulation system. They are looking for a few that do not work, to "experiment on" .
If you have any DO NOT THROW THEM AWAY. Send them to Flight systems.
If you have any more questions on this please contact Bob York at flightsystems at 1-800-403-3728.
I do not have ony as of yet but they still need some.
The scr goes under other numbers as well and the old number for the light board is b-292902 this is the older version.
The other lesser known scr pack they are looking for is the scr labeled A-233999, this is for the larger gensets.
Name:	kohler lightboard.jpg
ID:	240399   Click image for larger version
Old 03-11-2016, 04:09:00 PM
Default Re: Kohler Regulator, b-258545 , light board gm34505
UPDATE!!! WE NOW HAVE A WORKING and we think STRONGER scr pack as a replacement. we are currently looking for someone to put one in and test this unit for use. Bob York at flightsystems at 1-800-403-3728 for more information.
The Following 2 Users Say Thank You to BrianHaze For This Post:
Old 03-13-2016, 01:19:02 PM
ckelp ckelp is offline
how about the new SCR board on the fast response 3 generators? they have been out for two to three years and i've seen a couple fail, one went to full excitation.
Old 07-23-2018, 12:49:23 AM
GoldWinger GoldWinger is offline
Anybody have any other good/bad things to say about Flight systems product? specifically the SCR and board assembly...otherwise know as the heat sink assembly.
Old 01-24-2019, 03:49:23 PM
Default Re: Kohler Regulator, B-258545, Light Board GM34505
So Flight systems has ran into an unforeseen issue. Apparently their new scr pack has seen an issue where it spikes the genset when first fired up. this is not
a common issue since the has only been a few incidence out of a good bit sold. But enough to make them wonder. So Their heatsink, is set up with higher amperage and better reacting diodes. However the new photo boards are using a small transformer on them that is possibly effecting them. So They are looking for someone who would be interested in testing out one that has been modified to see if it works or not.
Old 01-24-2019, 10:51:17 PM
Zephyr7 Zephyr7 is online now
Their new diodes are probably the reason for the spikes. I’ve seen this happen in big motor drives before that have been “fixed”. The new diodes are faster so there can be faster rise/fall times and resulting spikes from the winding inductance. They can probably fix this with a simple snubber.
If this is the SCR pack that mounts on the armature, pleeeease have them round off the corners of the heatsink! Those things are a pain to replace and always scrape hands/arms while working on them.
Bill
Kohler Light Plant 2 KW, 110 VDC, Model KH needs regulator Wayne Johnson Kohler Generators 1 05-24-2014 02:01:48 PM
testing voltage regulator/circuit board help seifs5 Onan Generators 2 08-09-2010 09:39:54 PM
Schematic for YD Regulator Board needed Don Smith Onan Generators 12 05-30-2009 07:24:18 AM
15kw Onan voltage regulator board hoke_weise Onan Generators 15 03-22-2007 06:19:20 AM
Regulator board Steve G Onan Generators 6 01-07-2006 12:19:45 AM
