Go Back   SmokStak > SmokStak® Antique Engine Community > Hot Air Engines
Hot Air Engines Stirling engines, Rider-Ericsson and others.
Hot Air Engines
RIDER ERICSSON 6" - Brick - Cuir Piston Gasket
this thread has 46 replies and has been viewed 5311 times
Old 10-16-2017, 08:11:02 PM
Brent Rowell Brent Rowell is offline
Default Re: RIDER ERICSSON 6" - brick - cuir piston gasket
Davide,
I think Buster was referring to what he has found inside displacer pistons (your earlier question). Don Worley has spent some time (and money) finding the most suitable leather for Ericsson engines. You can get one from him that will fit and work without additional cutting, soaking, drilling or experimentation--and they're relatively cheap.
The Following User Says Thank You to Brent Rowell For This Post:
Old 10-17-2017, 03:19:49 PM
colo colo is offline
Originally Posted by Brent Rowell View Post
Davide,
As for Don's seals, he replied that he is not ready at the moment, and that he will tell me when he will make a new lot, but in the meantime I wanted to try it alone
The Following User Says Thank You to colo For This Post:
  #33
Old 10-17-2017, 10:47:02 PM
Buster Buster is offline
Colo In Post number 29 I was referring to displacer piston and how they were made On the piston leather get very soft leather about 1/16th thick smooth one side I think on 6 inch engine it needs to be 5 inch ID and 7 inches outside put white grease on it put it in smooth side to cylinder wall You are ready to go Try it keep me posted Buster
Old 11-05-2017, 06:23:37 AM
Yesterday I started building the collector for the furnace chimney
image by Davide Coloretti, su Flickr
The Following 4 Users Say Thank You to colo For This Post:
  #35
Old 12-02-2017, 02:40:36 PM
Here is the chimney collector finished
Senza titolo
---------- Post added at 07:40:36 PM ---------- Previous post was at 07:38:40 PM ----------
RIDER ERICSSON Restoration:
there is no trace of the great snowfall forecast for northern Italy.
So this morning I finished the paint stripping and then a good wash with the pressure washer.
The Following 3 Users Say Thank You to colo For This Post:
  #36
Old 12-02-2017, 02:54:52 PM
New question.
During the cleaning, 4 holes appeared around the cylinder, inside the perimeter of the furnace. They seem to have been closed with a kind of mortar.
Maybe they were for the gas furnace, and then the engine was converted to wood / coal?
BRANT, what do you think?
Senza titolo by Davide Coloretti, su Flickr
---------- Post added at 07:54:52 PM ---------- Previous post was at 07:49:44 PM ----------
New question, last for today.
When I disassembled the pistons, I noted the "tightening dimension" of the displacer.
This adjustment has to be very precise?
What would be the ideal setting?
Thank you
Old 12-09-2017, 04:13:32 PM
Today I practically finished the job. Only the water pipes are missing.
But for today, be satisfied with the photos of the pump
  #38
Old 12-11-2017, 05:05:43 AM
Brandon Pineo Brandon Pineo is offline
If you are speaking about the substance inside the dis-placer piston, in my engine it is mineral/rock-wool (which seems to be similar to an early fiberglass). I hope this is not exposed in any way as the engine will not run without a perfectly sealed dis-placer piston. DO NOT OPEN IT! If it looks good and there is no sealing issue, leave it alone and put it back in when restoration is complete.
The Following User Says Thank You to Brandon Pineo For This Post:
  #39
Old 12-11-2017, 05:29:22 AM
Hi Brendon,
yes my displacer looks good, I do not want to open it, it was just my curiosity.
Thank you
Davide
Old 12-13-2017, 05:15:26 PM
Hello,
the pump packing has two 1/4 "threaded holes.
It is original?
In the hole I have to put a tube to recover water leaks?
Thank you
Davide
Rider Engine Co. and Rider-Ericsson Engine Co. histories—Information Wanted Brent Rowell Hot Air Engines 15 11-25-2016 08:28:00 PM
Rider-Ericsson gt350shelb Hot Air Engines 9 01-01-2016 09:43:23 PM
Rider Ericsson leather piston ring Brandon Pineo Hot Air Engines 2 04-24-2015 12:57:21 PM
6in Rider Ericsson Steve Shearman Hot Air Engines 0 04-25-2009 09:27:18 PM
Rider/Rider -Ericsson Hot Air Engine ? Andrew Voss Antique Engine Archives 0 06-11-2000 01:38:54 AM
