Go Back   SmokStak > SmokStak® Antique Engine Community > Hot Air Engines
Hot Air Engines Stirling engines, Rider-Ericsson and others.
Hot Air Engines
RIDER ERICSSON 6" - Brick - Cuir Piston Gasket
this thread has 46 replies and has been viewed 5311 times
Old 12-13-2017, 05:57:17 PM
Marv in Minn's Avatar
Marv in Minn Marv in Minn is offline
Default Re: RIDER ERICSSON 6" - brick - cuir piston gasket
Originally Posted by colo View Post
Hello,
the pump packing has two 1/4 "threaded holes.
It is original?
In the hole I have to put a tube to recover water leaks?
Thank you
Davide
yes, the holes are for a drain tube in one and a plug in the other hole.
it is normal for the packing to leak a little.
if you tighten it enough to not leak, it creates too much drag on the engine.
marv in minn
restoring old iron, hot air engines and modelmaker.
The Following User Says Thank You to Marv in Minn For This Post:
Old 12-14-2017, 03:39:26 AM
colo colo is offline
marv in minn
Hi Mrv in Minn,
thanks for the information.
I have a new question, how should the pump packing gasket system be composed?
I have: pump + rubber washer + brass washer + rubber washer + brass stuffing box (with cone to house the packing).
It's correct?
ID:	298287   Click image for larger version
Old 12-14-2017, 09:24:23 AM
It's correct?
yes, that will work.
Old 12-16-2017, 02:55:25 PM
Default Re: RIDER ERICSSON 6" - Brick - Cuir Piston Gasket
I'm almost there, today for the first time I saw him move .... it's a show !!!!
I had a leak on the pump packing, but I've already solved it,
It's fantastic: a handful of wood, 10 minutes (but I would say even less) and the engine starts, fantastic!
Now just a nice outdoor video is missing, with the right light and perspective.
---------- Post added at 07:55:25 PM ---------- Previous post was at 07:51:42 PM ----------
I was afraid of not succeeding with the power piston seal.
I was afraid of the friction due to the glands and the pump, but instead everything was perfect.
Without water the engine goes very fast ... too much .... it was a great purchase !!!
The Following 9 Users Say Thank You to colo For This Post:
  #45
Old 12-24-2017, 07:59:48 AM
Finally the work is finished,
and this time I say it myself:
It came just fine 😃
I thank everyone for their valuable advice, and in particular Brent Rowell.
As promised here are the latest photos and a video ... take it as my gift for these holidays
MERRY CHRISTMAS 🍾🌲☃️
Senza titolo by Davide Coloretti, su Flickr
The Following 8 Users Say Thank You to colo For This Post:
  #46
Old 10-28-2018, 07:10:05 PM
Cajun Pickers Cajun Pickers is offline
Default Re: RIDER ERICSSON 6" - brick - leather piston gasket
Hello,
I’m restoring an Ericsson engine with a 5 in. power piston and im looking for some information on the main leather seal. I think the seal I have is going to need replacing, and so I was wondering if I could get Don Worley’s email.
The Following User Says Thank You to Cajun Pickers For This Post:
  #47
Old 10-29-2018, 06:46:11 AM
Hi Marv,
I do not have Don's private email.
But Don is in this forum, you can send him a message here:
https://www.smokstak.com/forum/priva...o=newpm&u=1221
he will answer you quickly.
Rider Engine Co. and Rider-Ericsson Engine Co. histories—Information Wanted Brent Rowell Hot Air Engines 15 11-25-2016 08:28:00 PM
Rider-Ericsson gt350shelb Hot Air Engines 9 01-01-2016 09:43:23 PM
Rider Ericsson leather piston ring Brandon Pineo Hot Air Engines 2 04-24-2015 12:57:21 PM
6in Rider Ericsson Steve Shearman Hot Air Engines 0 04-25-2009 09:27:18 PM
Rider/Rider -Ericsson Hot Air Engine ? Andrew Voss Antique Engine Archives 0 06-11-2000 01:38:54 AM
