Go Back   SmokStak > SmokStak® Antique Engine Community > Hot Air Engines
Hot Air Engines Stirling engines, Rider-Ericsson and others.
Hot Air Engines
6" Ericsson Hot Air Pumping Engine
this thread has 19 replies and has been viewed 2702 times
Old 09-04-2017, 10:10:37 AM
colo colo is offline
Default Re: 6" Ericsson hot air pumping engine
Originally Posted by Buster View Post
I would use A product called Fiber Frax and it comes in A blanket 1/2 inch thick .
Hi Buster,
the Fiber Fax, is a roll product similar to the picture, or is a slab?
Thank you
Davide
Old 09-04-2017, 02:54:26 PM
We used the fiberfrax on several hot air engine fire boxes at our museum and it works great. We fire with propane but I think you will be fine using wood.
The Following 2 Users Say Thank You to Bill Hazzard For This Post:
Old 09-04-2017, 03:07:57 PM
Hi Bill,
FibreFrax in rolls?
Old 09-04-2017, 07:30:24 PM
It was a used 1" thick roll that came off of a large muffler on a generator in a building.
Old 09-05-2017, 01:14:53 AM
Buster Buster is offline
Davide The Fiber Frax I used was in A roll like in the picture What I used was 1/2 inch thick and no problems ...When these engines were used for Large amounts of water the hot cylinder was hot enough to turn Red . When running at show they never get very hot and 1/2 inch is fine . just cut to fit and use 3M contact cement to glue it in Works good Buster
The Following 2 Users Say Thank You to Buster For This Post:
Old 09-05-2017, 02:13:38 AM
Thank you all for the information.
Buster, talking 3M adhesive for me is too general, you can send me a link?
Thank you
Old 09-10-2017, 07:32:09 PM
Brent Rowell Brent Rowell is offline
Default Re: 6" Ericsson Hot Air Pumping Engine
Another brand of this insulating material is "Kaowool" which I have used. I'm unsure of the effects of ceramic fibers on the lungs, so I use a respirator when handling this stuff.
Old 09-10-2017, 08:15:22 PM
I think that Kaowool may be same material The Fiber Frax I used I got from southern California May have the box and can get address I used 1/2 inch thick and worked good .It comes in A roll and can be cut with A small pair of shears The Glue to hold it in is 3M Super 77 part number 76098 I got it from wall mart or any of parts houses Hope this helps Buster
Old 09-11-2017, 03:49:45 PM
Thanks Buster, thanks Brent,
I purchased a fiber similar to FIBERFRAX, used to isolate the furnaces.
I did a test with a very powerful gas burner (I use it for starting hot bulb engine), the result was great, it did not get any damage, and definitely the firewood will have a less hot flame.
Then I bought a Spray Glue (hopefully similar to 3M super77) and finally I bought refractory bricks, I will put them only at the bottom of the furnace where there is wood.
Next week I hope I can post some photos.
Davide
Old 09-16-2017, 01:45:05 PM
Thank you all for your valuable advice.
In the end here is what I did today on the furnace:
a mix of refractory bricks and ceramic fiber (similar to FiberFrax).
Senza titolo by Davide Coloretti, su Flickr
The Following 4 Users Say Thank You to colo For This Post:
Improved Ericsson Hot Air Pumping Machine fogcity Hot Air Engines 5 07-29-2017 05:13:30 AM
Ericsson 6" hot air pumping engine bmck Hot Air Engines 10 05-23-2017 04:19:43 AM
rider-ericsson 10" pumping engine Owen Holton Hot Air Engines 11 10-06-2015 10:05:38 PM
Rider Ericsson Hot Air Pumping Engine now on eBay romash Hot Air Engines 10 12-29-2013 11:50:56 AM
Ryder Ericsson Hot Air Pumping Engine Harry Hot Air Engines 3 04-25-2009 05:41:35 PM
