Kohler Generators
Kohler 20RZ82 Not starting/No Fire
this thread has 30 replies and has been viewed 610 times
Old 02-11-2019, 09:53:42 PM
Zephyr7 Zephyr7 is offline
Default Re: Kohler 20RZ82 Not starting/No Fire
Originally Posted by RobbieBott View Post
@Zephyr7 Any luck finding that digital manual?
Yep, I have service manuals for the 20RZ. I have “them” actually — separate manual docs for the generator set and the controller. There is some info for the block heater install too. Surprisingly, there doesn’t seem to be a simple data sheet in the doc pack.
The genset manual is all the wiring diagrams for the generator end and controller. The engine manual has a placeholder saying you have to get it from ford.
I have an operation manual too.
I can email’em, PM me with your address.
Bill
I have three metal hoops (I'm guessing CTs) at the top of the alternator. One leg is looped around what I'm guessing is the first CT and the next leg is looped through the second CT, the third CT has nothing through it.
You need to wire it as shown in the drawing I sent. The CTs are “current transformers” and they look like doughnuts. If you only see “one leg” going through the hole in the middle of the CT, then that’s your problem. Find the other wire as marked on the drawing and pass it through the middle too. Each wire has to be in-phase (check the labels on the wires and compare them to the drawing, and has to go the same direction through the CT. The drawing is pretty clear (note where the dot on the CT is too, the wires need to pass through the side shown with the dot), make your unit like the drawing and you should be good.
Bill
Kohler 10RY62 starting issues Kohler Model 10RY62 Serial #451811 rhondabrwn Kohler Generators 2 06-23-2013 08:04:52 AM
Kohler 161T not getting fire gumsadma Magnetos, Ignition Coils and Spark Plugs 2 09-12-2011 09:14:38 AM
Kohler 5E wont fire jayjr Kohler Generators 3 05-31-2011 09:40:06 AM
Starting my 6.5 Kohler jmoorelewy Kohler Generators 2 09-08-2010 01:30:25 PM
Kohler K301 breathing fire dhiesel Small Air Cooled Gasoline Engines 10 02-11-2010 09:33:44 PM
