Kohler Generators
Kohler 30R82-91402A
this thread has 11 replies and has been viewed 367 times
Old 01-27-2019, 10:43:02 AM
drumfield drumfield is online now
Default Re: Kohler 30R82-91402A
2/3 of 31.25 kva is 20.83 kva.
Old 01-27-2019, 10:48:13 AM
Zephyr7 Zephyr7 is offline
Sometimes you donít have to derate at all for single phase output, but it depends on the generator end. If you derate by 2/3 (about 21kva) youíre safe.
In the past, on kohlers, all Iíve had to do to change the generator wiring config is to reconnect the generator leads and adjust the voltage adjustment pot until the output voltage is correct. I havenít had to make big changes to accommodate the voltage regulator. On your set, Iíd try making the wiring changes and seeing if you can just adjust your way to proper voltages. Going from 208v to 240v should be within adjustable range. Itís when you go from 208/240 to 480 that you need to be careful, usually.
Bill
Kohler 30R82 No Power Output DaneinWV Kohler Generators 19 01-07-2018 12:31:56 AM
Kohler 30R82 wiring diagram needed. THultz Kohler Generators 3 11-20-2010 01:19:35 PM
Kohler 30R82 Voltage Regulator Problems? alansaylor Kohler Generators 0 06-28-2010 11:01:34 PM
Need help with "new" 30R82 Kohler Genset forddog Kohler Generators 5 06-08-2010 04:55:52 PM
Kohler 30R82 information needed mxpilot Kohler Generators 0 12-23-2003 11:44:05 PM
