Kohler Generators
Newer Kohler standby problems....
this thread has 11 replies and has been viewed 353 times
Old 01-26-2019, 06:32:55 PM
1936JDB 1936JDB is offline
Default Re: Newer Kohler standby problems....
Thanks for the advice. The owner, the lineman installed it. There are several things I'd love to address some day. When its warmer..
Old 01-27-2019, 08:23:26 PM
Mark Dieckmann Mark Dieckmann is offline
IIRC those rocker switches are known to fail somewhat frequently. I think they get bugs and moisture inside. Check for voltage as suggested. Bat + on the center terminal and then out on the other two. The start wires should not make any difference. It should run without anything connected except fuel and battery.
The Following User Says Thank You to Mark Dieckmann For This Post:
Generac vs Kohler 20kw+ Standby Generator GeneratorNewb Generators & Electric Motors General Discussion 49 03-08-2018 11:09:58 AM
Help with newer Kohler motor interchangability? 1936JDB Small Air Cooled Gasoline Engines 2 10-01-2016 10:44:29 AM
Kohler Diesel 10ROY Standby Generator & Thomson Automatic Transfer Switch & Boyd Tank TC25D Kohler Generators 3 01-01-2014 06:34:25 PM
Kohler with Problems acarguy44 Kohler Generators 1 04-20-2011 08:27:22 PM
Kohler 35 Kw Standby Barber Colman Actuator Descentman Kohler Generators 3 06-02-2010 08:57:42 AM
