Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Horse Drawn Equipment
Horse Drawn Equipment Old iron designed for the purpose of hitching up to a horse or a team. This old iron machinery may be used or demonstrated while hooked to an old iron tractor too.
Hose Drawn Walk Behind Seeder
this thread has 1 replies and has been viewed 597 times
Old 09-22-2018, 11:06:57 PM
Mike Rock Mike Rock is offline
Default Hose Drawn Walk Behind Seeder
I have two of the seeders that were used between 42" corn rows to plant other seeds after cultivation ended. They use seed tubes smaller than a regular drill.
The tubes are the spiral steel type, the diameter is just under an inch at 0.95" and the length is 14"+/- a bit.
Does anyone know where I can find some of these, or twenty of them??
God bless.
Old 10-01-2018, 08:17:58 AM
Kent McMakin Kent McMakin is offline
Default Re: Hose drawn walk behind seeder
Mike. You might try Lakeside implement in Harrisville, Wi. I've gotten used ones up there in the past. Most of their parts and pieces are categorized as to types of machinery, out in the yard. I recall a couple pallets with various size tubes. Been a while tho.
The Following User Says Thank You to Kent McMakin For This Post:
horse drawn planter/seeder Fifty7ChevyNut Horse Drawn Equipment 4 12-04-2014 02:21:36 AM
Cultivator horse drawn walk behind jsjollyCO Horse Drawn Equipment 6 11-22-2013 03:20:16 PM
Horse Drawn Walk Behind Cultivator Floskap Horse Drawn Equipment 2 07-08-2012 10:00:52 PM
ID an old seeder mecoastie Farm + Industrial Antiques and Collectibles 2 09-10-2011 02:52:02 PM
