Unknown Marine Engine
this thread has 12 replies and has been viewed 1576 times
Old 03-12-2016, 04:00:45 PM
Mike O's Avatar
Mike O Mike O is offline
Default Unknown Marine Engine
Here is an engine that I have kicking around in the shed, I was doing a little spring cleaning and took some pictures to see if I could find out anything about it. As you can see it is a twin cylinder and definitely has marine engine in it.
2 things that I say are NOT marine is 1, it has 2 flywheels and 2 check out the muffler. and I would say it is NOT a "will fit" muffler because it is mounted on a 3 bolt triangle flange that lines up perfectly. I would NOT expect a muffler like this on a marine engine.
The previous owner must have thought a lot about this little engine because it appears to have had a broken piston and he went to a foundry and had real nice patterns made and had a new piston casted but unfortunately he passed away before machine it out and putting the engine back together.
It is missing the carb and it seems to me that it is a throttler because of the arm that comes off the vertical flyball shaft with an arm the I assume would have a piece of linkage to connect to the carb throttle shaft.
I know nothing about marine engines and would like to see if anyone out here can identify this one.
Also note on the opposite side from the governor you can see a plunger and eccentric for a water pump but NO pump body. There is another pump that came with the engine witch I think they were going to modify to the engine.
Thanks for your thoughts and impute! Mike
ID:	248756   Click image for larger version
ID:	248757   Click image for larger version
ID:	248758   Click image for larger version
The Following User Says Thank You to Mike O For This Post:
Old 03-12-2016, 04:03:15 PM
Mike O's Avatar
Default Re: Unknown Engine MARINE ??
A couple of more pictures
ID:	248761   Click image for larger version
ID:	248762   Click image for larger version
Old 03-12-2016, 06:07:59 PM
Bill Schaller Bill Schaller is offline
Default Re: Unknown Marine Engine
Looks like a Ferro to me.
The Following User Says Thank You to Bill Schaller For This Post:
Old 03-12-2016, 06:48:07 PM
RustySteele RustySteele is offline
Looks like a Ferro to me also.
The Following User Says Thank You to RustySteele For This Post:
Old 03-12-2016, 09:10:18 PM
Mike O's Avatar
Thanks for the info. I Google ferro and agree that this is what it is. Is there anyone interested in restoring this engine ? I would be interested in selling or trading it. Mike
Old 03-13-2016, 07:23:47 PM
ChrisinEstes ChrisinEstes is offline
What are you asking for it? About how much does it weigh? I have a Ferro Type 7 I'm working on... It might make a cool set.
Chris
Old 03-19-2016, 09:48:56 AM
Sad Iron's Avatar
Sad Iron Sad Iron is offline
Wow that thing is ugly, I like it...
Old 03-19-2016, 10:12:37 AM
Mike O's Avatar
Lol. I guess that is one way to look at it
Old 03-19-2016, 10:00:56 PM
J.B. Castagnos J.B. Castagnos is online now
I think it's a stationary engine. Double flywheels, governor, looks like a factory muffler, no water pump.
Old 03-19-2016, 10:06:12 PM
Mike O's Avatar
There is a water pump. At least 1//2 of one. I do believe it is a stationary version of a ferro marine engine
Unknown Marine Engine vern0n Unidentified Engines 4 08-08-2010 11:30:44 PM
Unknown Marine Engine ArtLinkloader Antique Gas Engine Discussion 1 04-10-2008 09:11:17 PM
unknown marine engine Canadian made Antique Marine Engines and Outboard Motors 20 04-08-2007 08:46:41 AM
unknown marine engine BDMelon Antique Marine Engines and Outboard Motors 5 10-28-2006 09:08:42 PM
Unknown Marine Engine GregSenn Antique Marine Engines and Outboard Motors 1 06-26-2006 11:20:42 PM
