Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
stupid question on maytag carb air filter( breather)
this thread has 3 replies and has been viewed 719 times
Old 05-04-2017, 04:02:20 PM
ehpower2 ehpower2 is offline
Default stupid question on maytag carb air filter( breather)
I have a 36 maytag with a screw type air breather. Does that thing just get jammed into the intake hole on the carb and then the screw snugged down a bit to loosely hold it in or is there a trick i am missing. I have mine in the hole and it is attached but to me it seems rather crappy way to hold it on the carb? Am i missing something?
Old 05-04-2017, 04:22:06 PM
Andrew Mackey Andrew Mackey is online now
Default Re: stupid question on maytag carb air filter( breather)
If your engine has the proper carb for your air filter, it will have a heavy squared boss on top of the carb inlet, for the set screw to tighten against. if your carb has just a rounded intake hole, with no heavy upper lip, it was built for the screen and O ring instead of the filter. On most of the screw filters I have encountered, previous owners overtightened the filter set screw, which in turn bends the screw mount. That allows the filter to wobble on the carb, and also allows dirt to bypass the filter. If you are careful, you can straighten the mount, and properly set the filter.
Old 05-04-2017, 04:25:54 PM
Ok mine is a round top carb and it came with the breather so it sound like that was incorrect. So i guess that it will not work with this motor.
Old 05-04-2017, 04:33:23 PM
Doug Oldenburg's Avatar
Doug Oldenburg Doug Oldenburg is offline
Like Andrew said....If it has the rounded top on the air intake, it should have just a fine mesh spring & heavy round snap ring. If squared off on top, should have air cleaner. By the way....Not a stupid question.......It's only Stupid to Not ask question's if a person has them.
"So Much Iron & So Little Money"
Maytag 92 carb question GlenK Maytag Engine Collectibles 3 05-07-2011 03:44:09 PM
Maytag Carb Question Roger Peterson Maytag Engine Collectibles 2 04-21-2011 08:54:54 PM
Maytag 1/2 hp Upright E Carb Question Clement Rook Jr. Maytag Engine Collectibles 3 01-26-2011 07:58:39 PM
Onan oil from breather clogs air filter Dave Jensen Onan Generators 7 10-13-2009 10:49:27 PM
Maytag 92 Carb question dragon Maytag Engine Collectibles 1 07-15-2006 11:17:22 PM
