Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
Maytag 72 magnet retention rivet
this thread has 6 replies and has been viewed 1025 times
Old 08-29-2017, 10:26:53 PM
Bill Fritz Bill Fritz is offline
Default Maytag 72 magnet retention rivet
Has anyone successfully replaced the aluminum rivet that helps retain the magnet in the 72 flywheel? If so, are they commercially available?
Old 08-30-2017, 04:47:34 PM
Exclamation Re: Maytag 72 magnet retension rivet
The magnet is permanently installed in the flywheel. It is not meant to be removed. If it has been taken out, you probably will have to get another flywheel. BE VERY SURE to replace with one of the same type. The 72-D and 72-DA use DIFFERENT flywheels, even though they look the same. The ID and magnets are different and wont cross match. The WICO flywheel is a class of its own.
I do not know of anyone who has replacement rivets, as stated earlier, the magnet was not meant to be removed. If the magnet needs re-charging, it needs to be done in place, in the flywheel. A regular charger is used with pole pieces to make contact with the magnet poles.
Andrew
Old 09-01-2017, 12:24:50 PM
Default Re: Maytag 72 magnet retension rivet
Thanks Andrew for the reply.
I have an otherwise good running 72, but with what appears to be a sheared-off head of the rivet in question (see photo). I've always wondered if there was a way to replace it.
Old 09-02-2017, 10:06:27 AM
Clement Rook Jr. Clement Rook Jr. is offline
bill, your magnet should still be tight,if so just put some high strength locktite around the stud ,let it dry good and forget about it.
clement
Old 09-13-2017, 02:37:14 PM
batrider batrider is offline
Default Re: Maytag 72 magnet retention rivet
Unfamiliar with the setup, but how about a pop rivet? They have them in aluminum and stainless.
Old 09-13-2017, 06:19:40 PM
The aluminum rivet is installed in the flywheel assembly, then machined when the OD of the flywheel is finished (Eissmann mags). A pop rivet will catch your hand as the engine turns If it ain't broke, don't fix it! As long as the flywheel magnet does not move, you should be OK. otherwise, look for a flywheel with a close S/N, and the same model type (D or DA)
Old 09-13-2017, 10:04:04 PM
DustyBar DustyBar is offline
Setting a rivet is more than just peening the head. If properly set the whole stem expands to fill the drilled hole. I bet there is enough friction to hold the magnet in place even if the head is gone.
Maytag 72da Magnet oldlabs Maytag Engine Collectibles 2 07-13-2016 05:36:07 PM
Maytag 92 Magnet Strength vascon2196 Maytag Engine Collectibles 4 08-14-2015 08:20:43 AM
Maytag 72 Magnet Attachment KSKRUSER Maytag Engine Collectibles 3 04-24-2015 10:54:22 AM
Maytag 82 / 92 Needs magnet rechared Who does this? bsatom Maytag Engine Collectibles 3 03-20-2013 02:30:53 PM
Maytag 72 magnet removal Rookesy Maytag Engine Collectibles 5 11-16-2012 03:30:37 PM
