Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
Maytag Model 92 Points
this thread has 2 replies and has been viewed 1263 times
Old 05-07-2017, 08:03:51 AM
pinball pinball is offline
Default Maytag Model 92 Points
Just got my first model 92 yesterday! they are a little different breed of cat aren't they? just going thru it & need to know what the points & plug gap at & just how do you set the point gap? can see the points thru the inspection plate hole in the fly wheal but not really shore how to adjust them! also I am curious to know what year it is? the S# is 575817 & it is a model 11.111
Name:	singel cylinder Maytag.jpg
Old 05-07-2017, 09:35:31 AM
coyote62ny coyote62ny is offline
Default Re: Maytag MODEL 92 POINTS
its been a long time since i worked on one of the 92 engines but the point gap is .020 i think the plug was .025 autolite 3095 plug is what i used the points are gapped by loosening the nut on the stationary contact and turning it there is also an adjustment on the govenor that will vary the point gap you should go on you tube and watch shop dog sam he has videos on the 92 and 72 maytag they will show you everything that you would want to know
Old 05-09-2017, 06:58:58 PM
Thumbs up Re: Maytag Model 92 Points
Pinball, your engine was built in early September, 1934. originally, the 92 used a Champion plug made for Maytag, the equivalent of the Champion #34 Gas Engine Special. You can find both on evilbay. Maytag plug in a Maytag looks great! The Champion X (Ford model T plug) will work too.
Points for a Maytag Model 92 pecker1951 Maytag Engine Collectibles 7 05-05-2016 12:05:58 PM
Maytag 92 need new points Harold Warner Maytag Engine Collectibles 2 06-07-2012 12:22:08 AM
Maytag Points allgattill Maytag Engine Collectibles 2 04-29-2011 07:56:46 PM
Maytag pinned points? cheddarhead Maytag Engine Collectibles 2 10-13-2010 08:29:45 PM
maytag model 72 how do you clean the points? Canadian made Maytag Engine Collectibles 2 10-29-2009 05:18:42 PM
