Unknown Barn Find Ecotrans? Help!
this thread has 11 replies and has been viewed 2866 times
Old 10-06-2017, 11:49:17 AM
Alexander Notarangelo Alexander Notarangelo is offline
Default Unknown Barn Find Ecotrans? Help!
We are a demolition/salvage company in Kitchener, ON Canada. This unit has been in our shop for years and I am just starting to move items around.
I was told it is an Auxiliary Locomotive Engine. I am not sure if this is correct, just relaying what I have heard.
Attached are the photos from our shop.
Please if anyone can give me some details on the unit, possibly what its worth as we salvage materials and would need a selling price for an engine like this.
Any help would be appreciated.
ID:	293006   Click image for larger version
ID:	293007   Click image for larger version
Old 10-06-2017, 07:42:53 PM
Default Re: Unknown Barn Find Ecotrans? Help!
By looking at the water pump and plumbing and lack of a radiator I'm thinking it was some kind of setup to keep a larger engine warm while supplying 120-240 60 htz current. I have no idea what voltage train passenger cars might use
Since it's made in Italy it could very well be a VM engine. VM Motori is currently owned by Fiat.
http://www.vmmotori.com/
Old 10-06-2017, 07:58:28 PM
Birken Vogt Birken Vogt is online now
Email NOT Working
That looks like a Kubota engine. Good engine. It is a Mecc Alte alternator which are a good "generic" brand. Some company just assembled them and slapped a label on.
Without a radiator or fan and with a questionable control system and no housing or soundproofing it is not worth a whole lot to most people. It would take thousands to get all those things together.
Old 10-06-2017, 11:10:09 PM
PFT's Avatar
PFT PFT is offline
Images: 31
That is an auxillary power unit for locomotives, it was used to keep the train powered up and warm when parked for extended periods. It was built by Advanced Thermal Dynamics (they changed their name to Ecotrans). That pump mounted on the side (the bronze part) with the long green shaft housing and pulley is built by Oberdorfer Pumps. The pump has some special parts used only for the application, early versions with standard parts failed due to the vibrations inherant in the setup.
PT
The Following 2 Users Say Thank You to PFT For This Post:
Old 10-07-2017, 07:08:27 AM
One thing badly not in it's favor to be installed into a locomotive is that it likely does not meet tier on the emissions.
Old 10-07-2017, 08:37:51 AM
PFT's Avatar
PFT PFT is offline
Images: 31
Here is a picture of the unit that came from their website early in production.
Old 10-16-2017, 05:55:54 AM
enigmapaul enigmapaul is offline
It’s definately a locomaitove apu. We used to work with them. The company is still in KITCHENER known as IMPCO. They are about $20k installed.
The Following User Says Thank You to enigmapaul For This Post:
Old 10-23-2017, 01:18:32 AM
Email NOT Working
Somebody threw an Autozone radiator on one and wants to sell it
https://sacramento.craigslist.org/fo...349479668.html
Old 10-23-2017, 09:45:16 AM
PFT's Avatar
PFT PFT is offline
Images: 31
That's the latter version where they eliminated the belt driven pump and it's problems. The direct coupled pump to the 3Ř motor is the way they should have done it in the first design.
PT
Old 01-20-2019, 12:18:31 PM
grifzila grifzila is offline
I paid $4250 for one of these surplus units. Someone had reconfigured it with an electric fan and radiator, removed the Aux. water circulating pump, Blocked the pump opening, added a fuel primer bulb and filter, rotated the exhaust muffler to exit to the side, moved the air filter inside the frame, and built an awesome (heavy duty ) compact trailer with electric brakes and 16 gal fuel tank. My guess is that it now weighs about 1300 lb.
The important components are well built. The turbo diesel has no trouble driving it's rated 17 KW. The diesel ~ 36 hp is governed to 1800 rpm, so is about the right size output power at the reduced run rpms. The engine and generator enable control is all relay operated - no micro possessor. It has over speed, over temp., and oil pres. shut down. There are analog oil press., engine temp. gauges plus digital voltage and hertz meters. One rotary switch will automatically cycle the glow plugs, delay cranking the engine, then delay another few minutes (warm the engine) before enabling the generator output.
Now the not so well designed: The locomotives they were heating with this APU use no antifreeze ( EPA ground pollution issue) . This means the Kubota cooling water has had a dubious life. I found one of the head freeze plugs was weeping - probably corrosion has burrowed under it's edge. Possibly the engine has been exposed to sub freezing conditions while stored or down for maint.
My unit showed a control problem (won't start, error faults, etc) because the 12v main (red) wire that supplies the control board (center back edge) plugs on with a standard slide on connector that is marginally able to handle the glow plug and other stuff. This should have been a screw stud. When it gets hot it goes to higher resistance and starves the relays. I found the problem on mine because the alternator was blasting the 900 amp AGM battery with over 15.5 volts while running. The alternator sense wire comes from the control board - so, when the board feed wire starts to fail, the sense wire voltage goes down - the alternator keeps adding voltage to bring it up the 14.5 v normal charging voltage. This is cooking the battery. You can't make the alternator (one wire - jumper the output to the sense wire to the alternator output post) because sense wire back feeds the control and the unit won't shut off normally or stop for errors.
Most of the circuit breakers in the control box are not used. They are what I call Euoro. setup . They clamp to ta mech. strip and power is on screw lugs on both sides of the breakers. This creates another design problem - The generator output goes through a 50 amp main breaker that feed a ridiculous copper buss strip with standard slide on connectors that were never intended to handle this current. From the buss, all the other circuit breakers are slide on connector jumpered from the "buss". The fix is just take the generator output from the main breaker instead of from one of the buss fed breakers.
I have been trying to locate detailed wiring diagrams of the unit from the manufacturer and other sources. No luck - Help! I have operating info and generator trouble shooting info but no details on the relay, over speed, and gauges wiring.
John
Unknown new barn find Seth Warren Antique Gas Engine Discussion 4 05-27-2016 09:08:11 PM
unknown barn find engine? Firewoodguy Unidentified Engines 8 12-26-2014 07:12:40 AM
My Own Barn Find lukeste Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 102 04-20-2014 09:52:41 PM
Barn Find newway1978 Antique Engine Photos 5 03-20-2014 07:26:50 PM
Barn Find John Deck Steam Stationary Engines, Traction Engines, Steam Boats 11 07-25-2011 11:14:30 AM
