Cheap Volts/Amps/Hz Meters
this thread has 7 replies and has been viewed 875 times
Old 12-23-2018, 11:18:25 AM
Cavalry Cavalry is offline
Default
My light tower had no meters of any kind for generated power which was rather annoying. I found these and they are pretty accurate for the cost. I rooted around in my collection for the IP45 box but if ones set was in a dry location they could be direct panel mounted. My only complaint is they are some weird Chinese dimensions and not any sort of DIN.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Photo...
The Following User Says Thank You to Cavalry For This Post:
Old 12-23-2018, 12:21:06 PM
Denola Denola is offline
Default Re: Cheap Volts/Amps/Hz Meters
I've used these gauges on several generators----I like to see at a glance how it's performing. It's also a good way to prove the unit is up to snuff if you are selling a used one. I, at least, put the AC voltmeter and DC voltmeter on the generators I use camping off grid----it takes a lot of guess work out of the picture----I've found they are pretty accurate when checked with my meter.
Old 12-23-2018, 02:28:04 PM
This inspired me to list a couple of meters in the classifieds
Old 01-09-2019, 12:35:07 AM
KrazyKarl02 KrazyKarl02 is offline
How long have you been using these cheap meters? I have seen them, but always cautious that after a while they would let their smoke out.
Old 01-09-2019, 12:48:50 AM
Only failures I've seen over about 8 years has been on the electromechanical hour meters. They work great, except the electronics board inside isn't issolated very well mechanically. Over time vibration fatigues and breaks the solder connection on filter cap. Same failure has happened to at least 4 meters (which is probably why they vanished from new generators.)
Doc
"I could while away the hours communing with the flowers if I only had a brain.."
Old 01-09-2019, 07:50:17 AM
I used two of these, one on each leg for the 6.5 kW I just worked on.
https://www.ebay.com/itm/AC-80-300V-....c100005.m1851
Accuracy is ok. Current readings are spot on. Voltage reading is off a few volts.
They have a button to reset the kWh reading.
Old 01-09-2019, 12:06:56 PM
Bob Willman Bob Willman is offline
Marlin P. Jones has a variety of digital panel meters available.
Bob
WB8NQW
The Following User Says Thank You to Bob Willman For This Post:
Old 01-09-2019, 12:36:58 PM
I too have used some of these cheap meters, good value for lots of applications. My only concern is the voltage connection in the event of a fault inside the meter. The full generator output would be applied to the fualt. I would suggest a fuse in the voltage circuit. A fuse rated for the voltage, of sufficient breaking capacity, and a low current rating. This usually means a ceramic body with an inert filling.
onan OTC 120 volts but 0 amps? YellowLister Onan Generators 7 10-05-2013 10:19:57 AM
Cheap Meters, Volts, amps, and frequency! bbuchorn Onan Generators 10 03-10-2012 04:49:44 PM
Cheap Meters for the Onan JC Ted_Cool Onan Generators 32 02-26-2011 04:22:34 PM
Volts & Amps out of Briggs & Stratton ignitions? Wolfy1 Magnetos, Ignition Coils and Spark Plugs 6 03-29-2009 09:54:58 PM
Amps & Volts?: 5.0CCK-3CR/9863V w peterson 54 Onan Generators 3 03-08-2008 11:07:29 PM
