Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Honda, Yamaha, Kawasaki, Isuszu Generators
Honda, Yamaha, Kawasaki, Isuszu Generators Restoring, maintaining and operating Honda, Yamaha, Kawasaki, Isuszu, and clones.
Honda EU7000is vs Eu6500is
this thread has 21 replies and has been viewed 3428 times
Old 04-06-2018, 10:15:43 AM
GeneratorNewb GeneratorNewb is offline
Default Honda EU7000is vs Eu6500is
Hey guys,
I was just wondering if you guys have experienced any issues with the newest Honda EU7000is fuel injection systems.
Some of you have stated that these generators have experienced issues with the fuel injection and I was just wondering if that is something that has been fixed.
If there are still issues with the fuel injection I will opt for a used EU6500is despite having 500 less surge watts and no 3 year warranty.
Thanks in advance for your help!
Old 04-06-2018, 10:54:31 AM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Honda EU7000is vs Eu6500is
Our Resident SmartGuy for everything Honda, will be along shortly... Robert of Honda can answer that easily.... StandBy for news....
Bruce in alaska
Old 04-06-2018, 12:43:10 PM
Fred M. Fred M. is offline
Default Re: Honda EU7000is vs Eu6500is
My EU6500is has weathered several storms. I get around the problem of carburetor getting gummed-up by using 100 Octane aviation fuel. That has held up several years without any trouble.
Why would I upgrade to the EU7000is? One reason might be if fuel injection gets more hours out of a gallon of gasoline.
I understand that fuel injection has less trouble with old gasoline. Ordinary gas would be less expensive than aviation fuel.
Fred
Old 04-06-2018, 06:02:35 PM
AlexV AlexV is offline
Originally Posted by GeneratorNewb View Post
Hey guys,
I owned both. I sold my EU6500 to buy another EU7000 so I could parallel them. The EU6500's were prone to surging if the air box gasket was bad, or the battery door was off or if you ran it without a battery. The EU7000's has a redesigned air box and has no problems with surging. No carburetor problem because its fuel injected. If you could find a good used low hour EU6500 at a great price its worth looking into. Honda's NOT doing the parallel kit for the EU7000's so that's off the table.
Old 04-06-2018, 06:12:12 PM
Thanks so much. I just ordered 1 form Electric Generators Direct. Backordered til next week.
I was initially going to buy a Generac standby unit but after hearing some of your feedback on this forum, I've lost my faith in Generac to be there for my family when we need emergency power
Old 04-06-2018, 07:32:04 PM
GreasyIron GreasyIron is offline
Why did they quit making the 7000 version? I thought it did exist for a while; it was discussed in this thread a while back. Not that I need it, but now curious anyway.
Old 04-06-2018, 11:37:00 PM
My understanding is the breaker kept tripping under normal load. The problem with paralleling 240v is the generator's don't pickup the load equally and you get a buildup of neutral cross current. Its no good for the inverters. Honda really does need to build a true 50 amp 240v generator for home backup. I took a look at a few different diesel generators but my main problem is rotating diesel fuel. I have no way to do it. The EU7000 parallel kit would have been perfect for me. its a major letdown
The Following User Says Thank You to AlexV For This Post:
Old 04-07-2018, 11:51:58 AM
DLester DLester is offline
My EU7000 puts out smoky exhaust for a surprisingly long time after a cold start. It has done so since new. I’m not qualified to say whether it’s normal, but it sure is annoying. I wonder if there’s something amiss in the injection. There is no other indication of trouble - it makes steady RPM and puts out power, and once it’s warm, the exhaust clears up.
Fred M - I use 100LL aviation gas in a lot of my engines, but not in the Honda. I have read the engine has an exhaust catalyst, and if so, the leaded fuel would probably kill it. The controller might not like that.
Old 04-07-2018, 09:41:03 PM
Is there any harm if I use synthetic 5w30 vs synthetic 10w30 I'm the eu7000is?
The coldest it ever really gets here is -10F. Is there any downside to using the 5w30 or is it unnecessary? Thanks so much!
Old 04-07-2018, 11:36:50 PM
If I lived where the temp dropped to -10 I would be using 5W30 I use to change my oil twice a year. In April I would put in 10w30 and in the winter 5W30. Now I just run 10W30. Here in NJ it doesn't usually get that cold. If I saw temps below 30 I would run 5W30 in the winter. I would want the oil to start splashing around as soon as possible. -10. That's cold.
Honda EU7000is Parallel Kit MrRedHat Honda, Yamaha, Kawasaki, Isuszu Generators 38 07-01-2018 04:04:58 PM
Honda Eu6500is Help roadster guy Honda, Yamaha, Kawasaki, Isuszu Generators 7 02-19-2018 07:14:41 PM
Honda EU6500is NOOB Hard Starting Question DGKula Honda, Yamaha, Kawasaki, Isuszu Generators 14 08-09-2016 09:24:20 AM
Honda EU6500IS no AC output TaprackFire Honda, Yamaha, Kawasaki, Isuszu Generators 5 02-13-2016 10:34:11 PM
Honda EU6500is Model Number for Parts? DGKula Honda, Yamaha, Kawasaki, Isuszu Generators 1 12-14-2015 12:24:57 PM
