Fairbanks Morse belt driven generator?
this thread has 2 replies and has been viewed 3088 times
Old 09-25-2007, 04:14:08 PM
Images: 10
Default Fairbanks Morse belt driven generator?
I've been asked (nicely) to get this Fairbanks Morse belt driven generator working for a friend.
I'm sure I can trace every thing down and get it working, but a wiring diagram could save me some time. Would any one have such an animal as a wiring diagram for this unit? I would certainly appreciate the help.
The engine serial number is: 400902, according to my list that would make it a 1919. I haven't really looked at a lot of those Z engines, but the Bosch trip magneto doesn't look like one I have seen on those engines.
This link will take you to my "photo gallery" and you can look over the pictures I've put there.
http://www.smokstak.com/gallery/brow...&imageuser=467
Thanks for any help you can provide.
"DELCO DON" Southern Illinois
Old 09-25-2007, 11:29:30 PM
Andrew Mackey Andrew Mackey is online now
Exclamation Re: Fairbanks Morse belt driven generator?
Hi Don,
I have a hand drawn wiring diagram I made from a F/M owners manual, #2575E. It is for a slightly later unit, but I think it will work. Are all the workings still mounted to the plate above the generator frame (current selector switch, resistor, fuse, terminal block)? I believe the engine ignition may have been changed, or the engine even replaced, as the 'Special Electric' units usually put on these frames, used a timer and coil, powered by the battery set - through the generator, and the resistor block. Send me an E.M with your info, and I will send you a copy of my diagram. If you can locate a copy of the F/M 2575 booklet, it is pretty useful.
Old 09-26-2007, 05:18:02 AM
Default Re: Fairbanks Morse belt driven generator?
Looks like you're working with an AB-34 magneto, correct? They don't have the familiar brass grounding brush holder on the top of the housing that the AB-33's have.
I have some literature on similar lightplants tucked away and I think there is a wiring diagram or two. It may take a couple days to dig down that deep though.
I will let you know what I find.
Belt Driven Ice Cream Maker steam4fun Scale Model Engineering 6 03-25-2008 02:56:53 PM
Belt driven machinery Casemaker Farm + Industrial Antiques and Collectibles 4 01-07-2005 09:14:04 AM
Vintage Flat Belt Driven Onan Generator - Need Parts John H Onan Generators 2 11-20-2004 05:48:09 PM
Belt Driven Pumps !! Jim Tremble Antique Engine Archives 0 02-26-2003 11:51:13 PM
