Smokstak Down Under
Multi stage centrifugal pump
this thread has 10 replies and has been viewed 2056 times
Old 06-01-2010, 06:58:57 PM
jopeter jopeter is offline
Default Multi stage centrifugal pump
I picked up a small multi stage pump .It's a Siemans and Hirsch . Four stage ,side entry with four open sided bronze impellors . My guess is that it is a feed pump ,maybe on a small boiler. Interestingly it was direct coupled to a Villiers Mk12 engine .....so if it was producing high pressure output it obviously did not require a high HP input to drive it . What can I do with it ????
Old 06-01-2010, 07:29:39 PM
jht1057 jht1057 is offline
Default Re: Multi stage centrifugal pump
Post some pictures.
Jim
Old 06-02-2010, 04:04:16 PM
Teddey Teddey is offline
Wink Re: Multi stage centrifugal pump
Send it to me!!
Teddy
Old 06-02-2010, 05:51:46 PM
Jim........yes I will,Ted you can have it if I can not find space in the shed for it !
I am wondering if it will provide a decent load for an engine .
Old 06-03-2010, 03:32:01 AM
Siemans and Hirsch Multi stage centrifugal pump.
The Following User Says Thank You to jopeter For This Post:
Old 06-06-2010, 06:20:25 AM
Sorry about the image of the multi stage pump ....here it is.
Old 06-06-2010, 05:55:48 PM
Walky Walky is offline
Jopeter
do you think it was worked with the Villiers engine as a feed pump?
or was cobbled up to move some water at low pressure?
Walky
Old 06-06-2010, 07:09:17 PM
Walky...The person who gave me the pump doesn't know what the pump was used for . It was definately driven by the Villiers and if it was a boiler feed pump then the water quality was not to good as the internals of the pump are scaled . Otherwise it is OK . I am going to belt it up to a 5 HP Sunshine two stroke with some 1 inch pipe work and see how it performs . I suspect it will be low volume / high pressure .
I'd be interested in any comments .
Old 07-06-2010, 03:56:23 AM
Gunna Gunna is offline
Peter,off subject but I was wondering if you could assist me with details of a replacement filter element to replace the large cloth filter in the Southern Cross YB diesel engines.I seen the info on the net somewhere and cannot relocate.Gunna.
I am also a member of TOMCWA and will send you a private Email.
Old 07-06-2010, 08:02:10 PM
I couldn't find ANY information searching Siemans and Hirsch......I DID, however, come up with many results searching for Siemens and Hinsch pumps
http://www.google.com/search?hl=en&c...+pumps&spell=1
The second result leads to the TOMM forum which you can't DECENTLY view without creating an account....... ......but you can see enough.......
Fairbanks Morse centrifugal water pump zukesofhazzard Farm + Industrial Antiques and Collectibles 2 01-14-2010 04:56:56 AM
Pump Jackwith multi-ratio gears Clif Roemmich Farm + Industrial Antiques and Collectibles 10 10-22-2009 07:24:18 PM
Deming centrifugal pump ArtLinkloader Farm + Industrial Antiques and Collectibles 0 07-29-2009 09:21:04 PM
Goulds flat belt centrifugal pump OLD Harry Antique Engine Archives 3 07-10-2002 04:02:51 PM
Fairbanks Morse Centrifugal Pump Tom Fisher Antique Engine Archives 0 02-23-2000 01:37:45 PM
