Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Generac Generators (SEARS, etc.)
Generac Generators (SEARS, etc.) Restoring, maintaining and operating Generac generators.
Question re. Homelite Textron Generator G-3600-2
this thread has 3 replies and has been viewed 4111 times
Old 09-17-2010, 10:32:55 AM
walkingbc walkingbc is offline
Default Question re. Homelite Textron Generator G-3600-2
First: Is this the best place to post a question about this generator?
Second: I'd love to get my hands on a manual.
Third: (Deleted)
Fourth: It has a main 30Amp breaker and two smaller ones which go to the two standard 15/20 amp outlets. One of the smaller is broke/missing and I can't tell what Amperage to replace it with. Any one know what the two smaller breakers are supposed to be or where to get them? or have a manual that could help?
Wade
ID:	87682   Click image for larger version
Old 09-20-2010, 12:18:26 AM
armandh armandh is offline
Default Re: Question re. Homelite Textron Generator G-3600-2
gen end looks similar to mine [a 7.2 KW]
it looks as if it also uses a K series Kohler engine [mine is a flat twin]
then the engine details are available as a down load PDF
http://www.kohlerengines.com/onlinec...eries=K-Series
more specifically for your engine this service manual
http://www.kohlerengines.com/onlinec...df/tp_2379.pdf
the voltage regulator is quite simple 120 volts goes through a series inductor and is rectified and filtered then to the field brushes. each of the two hot 120v out put lead takes a few turns through the inductor in opposite directions.
current in the inductor output windings works in opposition to the series loss in the field supply winding
mine is rock solid and runs great
the voltage right on [once the engine speed is right]
http://www.smokstak.com/forum/attach...1&d=1179334731
on mine the larger breaker feeds the twist lock and smaller fuses sub feed the duplex outlet
duplex outlets with the N side T shaped slots are 20A [only straight slots then 15A]
CAUTION when the outlet is replaced the tab must be broken between the hot screws as each side gets half the 240 to use all the output. in the past some one may have not done this and just left out the breaker.[as it was always tripping] but that only delivers half the generator output.
after the photo above I replaced both of my sub fuses with 20A push type breakers.
from an auto supply online
http://www.google.com/products?hl=en...ed=0CDcQrQQwAg
if it is [as it appears to be] a Kohler engine,
that area may be a better place to post engine related questions
and if unknown post in the main thred
mine seems to be very well built with plenty of reserve
yours is the only other one of these I have ever seen on this web site
Old 09-21-2010, 03:15:23 PM
Thanks so much for your responce. I understand about the tab. The duplex is 20A and wired correctly and possibly never replaced. The wires look original as well but I wonder if they are good for 20A. The generator is rated at 30A and I think the main breaker is 30A. Considering all that, I thought two 15A breakers for the duplex makes more sense. I could be wrong. Any thoughs?
I don't understand what you said about the generator itself and don't think I need to.
How much would you sell yours for, in other words, how much do you think mine is worth on craigs list or on one of these sights?
Wade
Old 09-21-2010, 05:58:58 PM
since the small 20A breakers are after the larger 30 they protects the outlet
if wired 120 only the 30 would protect the generator
if wired 120/240 two 15 amp breakers are good
15 X 240 = 3600
think of it as
15 X 120 = 1800, twice = 3600
were it mine I would not sell
is that the right kohler engine?
attached is the gen end / regulation on mine, probably similar to yours.
[hand drawn from memory, does not reflect layout, only function]
yours may be bonded earth to neutral, [3 prong 30A twist lock]
mine was when aquired, but was (re)isolated for it's intended use. [4 prong 30A twist lock]
Homelite Generator wilsont Generators & Electric Motors General Discussion 11 05-19-2018 06:46:44 AM
A curiosity question - 1800 vs 3600 RPM Gensets Alchymist Generators & Electric Motors General Discussion 7 07-13-2010 12:05:14 AM
Flywheel Sears Craftsman 3600 generator ron_a Generac Generators (SEARS, etc.) 2 04-08-2007 12:19:06 PM
Question about 1951 Homelite ac Generator JKistnerJr Generators & Electric Motors General Discussion 16 10-07-2006 05:35:38 PM
New question re: Homelite Stans Generators & Electric Motors General Discussion 14 11-07-2005 10:19:34 AM
