Onan JB Propane
this thread has 127 replies and has been viewed 6050 times
Old 10-06-2016, 05:42:20 PM
EnginePat EnginePat is offline
Default Onan JB Propane
Hey guys I'm back all better and a new project.
I found this jb just down the road. It has mouse in the lower control box. I will clean it out and see how bad it is.
ID:	264710   Click image for larger version
ID:	264711   Click image for larger version
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
The Following 2 Users Say Thank You to EnginePat For This Post:
Old 10-06-2016, 06:43:56 PM
Default Re: Onan jb propane
So what would be the best cleaner to use to clean the mouse crap/urine residue out. Without ruining anything else.
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
Old 10-06-2016, 07:11:26 PM
How bad is it? Any pictures?
I would vacuum it out.. then use some kind of cleaning.solvent.. after you cover the relays
. Then.let it dry out for a few days.. if it's not to far.gone
Old 10-06-2016, 07:15:30 PM
I will get more, tomorrow. Some of the screw heads are gone when I took off the cover. The top cover where the board is was clean.
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
Old 10-06-2016, 07:21:23 PM
JohnnyC JohnnyC is offline
Several years ago I bought a 15.0 JC. The control box had condos and town houses of mice nest. I ended up removing all the components and wires to allow complete removal of mice damage and to paint the metal to look new. Also, I had to rewire the entire control box for two reasons; 1) The mice chewed on some of the wires in addition to peeing/pooping on the wires and 2) A genius from the past decided to modify the wiring and did a butcher job.
JohnnyC
New Jersey
The Following User Says Thank You to JohnnyC For This Post:
Old 10-07-2016, 12:37:31 PM
Charlie Foxtrot Charlie Foxtrot is offline
Non flammable contact cleaner works well on the electrical bits. Febreeze kills the smell. An added plus, Febreeze tends to repel the critters. Contact cleaner may wreck the paint, tho.
Old 10-07-2016, 01:38:42 PM
len k len k is offline
Think I'ld clean it out then paint the inside of box. I repaired a microwave that had a triac on circuit board die and cook the board. One terrible burn smell. I just cleaned then painted the board with clear paint. All smell disappeared , it locked the smell under the paint.
Old 10-08-2016, 11:10:25 AM
So the bottom of the control box is full of , well you know what. A couple of wires are chewed off. The heads of some screws are gone. I'm sure there is more. I will need a terminal block for the bottom for sure and the aluminum heat sink. Its a mess.
ID:	264841   Click image for larger version
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
Old 10-08-2016, 02:23:38 PM
nothingbutdarts nothingbutdarts is online now
Penetrating oil can be your friend on the exposed relay, get the junk out of the box and start soaking it for a while before trying to unscrew anything. I ended up reusing the heat sink on my unit even though it had corrosion on it which I cleaned up as best I could.
Old 10-08-2016, 02:42:33 PM
I went an got some new bags for the shop vac. I don't want that crap in it. Raining now so tomorrow's another day.
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
Onan 705 cw gas to propane kit rick ellison Onan Generators 8 06-01-2012 12:51:11 AM
Onan 12.5 JC Propane rodymartin Onan Generators 4 02-27-2012 09:20:43 PM
Onan 2LK propane ?'s discodog1 Onan Generators 4 12-12-2009 11:51:07 PM
Onan 12.5 JC Propane rodymartin Onan Generators 2 03-20-2007 07:19:33 PM
