1916 Dodge Brothers Roadster
this thread has 31 replies and has been viewed 4043 times
Old 11-07-2017, 10:14:23 PM
Chris Props Chris Props is offline
Default Re: 1916 Dodge Brothers Roadster
There wasn't much wrong in the transmission. The cork seals were gone so I installed sealed bearings, but that was all it needed.
ID:	295575   Click image for larger version
ID:	295576   Click image for larger version
The Following 3 Users Say Thank You to Chris Props For This Post:
Old 11-07-2017, 10:45:27 PM
When I got the transmission back together it wanted to lock up in some of the gears. I found that one gear was slightly engaged with the reverse idler when it shouldn't be. Notice in the first picture how the reverse idler gear is slightly offset.
It turns out the cover had been cast with the oil level lettering upside down. Flipping the cover over fixed problem. I remember reading that the Dodge brothers liked to drink...
ID:	295579   Click image for larger version
The Following 2 Users Say Thank You to Chris Props For This Post:
  #23
Old 11-08-2017, 07:24:56 AM
Elden DuRand's Avatar
Images: 11
Chris:
In the third photo in post 21, there is a spiral gear in the transmission. What is it for? Speedometer drive?
Take care - Elden
http://www.eldensengines.com
Old 11-08-2017, 09:55:19 AM
Yes, that's the speedo drive gear.
Old 11-08-2017, 08:38:47 PM
Images: 11
Chris:
Wow! What an unusual place to put the speedo drive gear.
Take care - Elden
Old 11-15-2017, 10:24:18 PM
I hadn't planned to tear it down this far, but one thing led to another. Here is how it sits now.
  #27
Old 11-15-2017, 11:13:35 PM
Old 11-17-2017, 01:52:42 PM
OTTO-Sawyer's Avatar
That's The Best Way to do it in the long run.
Old 11-18-2017, 02:52:40 PM
At first glance the body didn't look too bad, but the media blaster tells the truth. Someone had recently filled the seat pan with fiberglass and covered it with a bedliner like material. The other areas I knew about, but the seat pan and back came as a surprise.
ID:	296345   Click image for larger version
ID:	296346   Click image for larger version
ID:	296347   Click image for larger version
The Following 5 Users Say Thank You to Chris Props For This Post:
  #30
Old 12-10-2017, 09:32:05 AM
P Schmidt's Avatar
P Schmidt P Schmidt is offline
When I did my '25, I purchased the piston from http://www.then-now-auto.com/ They were either slant six pistons or half a set of mopar V8. The ones you have appear to be hemi pistons.
The Following User Says Thank You to P Schmidt For This Post:
Dodge Brothers Engine Help Bob Bachman Antique Autos and Trucks 21 02-15-2016 06:24:33 PM
Dodge brothers Four Help Catmatt2375 Antique Autos and Trucks 3 02-04-2016 03:44:19 PM
1926 Dodge Brothers gratchili Antique Autos and Trucks 10 06-16-2015 04:36:55 PM
The Dodge Brothers. Denis Rouleau Antique Gas Engine Discussion 14 03-10-2013 10:38:17 AM
