Case CrossMount Spark Plugs
this thread has 11 replies and has been viewed 1934 times
Old 07-28-2008, 03:52:15 AM
Harry Henderson Harry Henderson is offline
Default Case CrossMount Spark Plugs
Hello, Anybody know where I can get a set of spark plugs for my Case 18/32? It has Champion C-5's in at the moment. Thanks in advance!
Old 07-28-2008, 09:41:29 AM
19-65Port 19-65Port is offline
Default Re: Case CrossMount Spark Plugs
se Autolite 3077 you can order them at ay auto parts store and are half the price of champions
The Following User Says Thank You to 19-65Port For This Post:
Old 07-28-2008, 07:37:40 PM
greysteam24hp greysteam24hp is offline
Email Over Quota
Images: 100
Autolite 3077 sure do good on my Greyhound gas tractor. One round crank start her up. It is large antique alike wired gap spark plug. I use 30 gap check. I formerly used Champion is somewhat hard for large low compression cylinder. Napa store is where I ordered. I usually buy quantity box rather than individual piece at discount price. I can use spare spark plug just in case when failed.
Craig
The Following User Says Thank You to greysteam24hp For This Post:
Old 07-29-2008, 01:09:11 PM
Thanks for the info, I never even thought about Autolite. Just shows what a good web-site this is and what knowledge is out there Thanks again, HH
Old 07-29-2008, 03:20:44 PM
Robert Holt Robert Holt is offline
Hi Harry please can you get 2 sets as i need some for my old girl, i only live just down the road in Leicestershire. thanks....Robert
Old 07-29-2008, 10:53:35 PM
I have enjoyed great service from these Autolite plugs. I use 3076 in many of my "newer" tractors and the long reach hotter 3077 in my old low compression steel wheeled machines. There is also a 3095 pipe thread version for those who need it.......these plugs work well and are priced below several other brands.
Robert, can you boys get these plugs on your side of the pond?
Pay the shipping and I will send you some if they are hard to find over there
Old 07-31-2008, 03:12:02 AM
Richard Sturdy
Harry, What's wrong with the old C5's? They are pretty "hot" and work better than modern plugs in most ancient machines. Do you have an actual plug problem, or are you just wanting to fit "new" plugs with an "old-fashioned" heat rating?
Tricky Dickie
Old 07-31-2008, 06:23:51 AM
Photo Re: Case CrossMount Spark Plugs
Richard, That's a good question, I have one of the plus in my car and the more I look at it the more I think its not that bad. Maybe I will dismantle and clean up the plugs I have. I have had the mag re-built so in the next week or so I will attempt to start the tractor for the 1st time in ten years and see how it goes from there.
I have included a photo of the tractor in question. And yes, I know its the wrong color!! It will need to be re-painted in the fullness of time. HH
Name:	Self Prop 004.jpg
The Following User Says Thank You to Harry Henderson For This Post:
Old 08-01-2008, 12:51:24 AM
The 3077 will make it run much smoother than the c-5 because they are very long. It will also start easier and idle better old looks are great but a sore arm from cranking is not fun
The Following 2 Users Say Thank You to 19-65Port For This Post:
Old 08-01-2008, 01:35:27 AM
Email Over Quota
Images: 100
This is a large 3077 Autolite old style spark plug. Photos enclosed.
ID:	36875   Click image for larger version
The Following 2 Users Say Thank You to greysteam24hp For This Post:
1/4 - 32 spark plugs Dan Hodge Antique Gas Engine Discussion 10 12-10-2012 03:04:04 PM
Spark plugs for 6.5 NH ?? Packard8 Onan Generators 6 10-24-2007 03:25:18 PM
Tractor ID's, Rumely and Case Crossmount KevinF Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 07-19-2006 12:08:51 AM
Spark plugs ( first used) Dan Barson Antique Engine Archives 2 08-06-2004 08:44:31 PM
Spark Plugs D.J. Baisch Antique Engine Archives 3 05-16-2002 01:16:07 PM
