Me 1 Western Electric 0
this thread has 3 replies and has been viewed 674 times
Old 09-04-2018, 07:54:41 PM
Mike Schweikert's Avatar
Images: 26
Talking Me 1 Western Electric 0
This is one of 2 Western Electric Light Plants I have.
Serial 4889 probably pre 1921 as it does not have oil check valves in the crankcase cover or main bearing. This plant was hard stuck. I broke the pulley on the end shaft by trying to turn it with a pipe wrench...(if someone has one, Id be interested)…...I learned the hard way that the crankcase cover can be removed and then just unbolt the con rod and cylinder and remove to help remove the piston. I had got it to move about 2 inches then no dice.
The crankcase had a hard crust of oil over a inch thick. It must have been stuck for 50 years. I have never seen one so bad before. I've cleaned it out now, removed the oil pump, cleaned that, then freed the governor weights and oil pump rod.
I turned the cylinder upside down and cleaned the rust and gunk from the walls to give the piston a chance to move. I then removed the bearings and turned the crank so the rod could hang freely down when cylinder was bolted back on. Got a BMF sledge and wood and smacked it good. Here are the results.
The rings are interesting as they are pinned and cut on a slant. Ive never seen that before. The piuston pin uses a small pin in the end of the screw inside the bushing to hold it there.
So after 2 months of MAP gas, oil, trans fluid and acetone, here we are....
Thought someone might find this useful...….hope I find a pulley....
ID:	317943   Click image for larger version
ID:	317939   Click image for larger version
ID:	317940   Click image for larger version
Mike Schweikert
Jamison PA
The Following 7 Users Say Thank You to Mike Schweikert For This Post:
Old 09-04-2018, 11:58:35 PM
K-Tron K-Tron is offline
Default Re: Me 1 Western Electric 0
Mike, that is a really interesting piston/ring combination. I think your best bet towards cleaning that piston and saving the rings would be to submerge it in a heated ultrasonic cleaner for a day or two. I have had great luck using that method to free up seized small engines and the like.
The Following 2 Users Say Thank You to K-Tron For This Post:
Old 09-07-2018, 07:34:41 PM
Images: 26
UPDATE
Dammitt, of course broke one ring trying to free them.....The top ring was fused to the land, even with map gas and gentle persuasion with a feeler guage...
The pins are small screws that were either chiseled or shaped to hold the rings.
They are 3.500 by 0250. I suppose I will have to Dremel them flat and use standard rings....
Now its me 1, Western Electric 1...…..
Mike Schweikert
Jamison PA
Old 09-08-2018, 04:01:30 PM
see one of our sponsors for new rings. I would get them with overlap ends and put the keeper notch in another location so gasses can't get by the pin.
western electric generator help Chris Wheeler Generators & Electric Motors General Discussion 13 08-15-2013 09:18:26 AM
Western Electric 120kw porbob Military MEP and Aircraft Gen-Sets 2 07-04-2008 01:10:15 PM
Need help, Western Electric Gen Joe Musser Generators & Electric Motors General Discussion 3 01-03-2005 06:12:42 PM
8B Western Electric Phil Robinson Generators & Electric Motors General Discussion 0 08-18-2004 09:41:49 AM
Western Electric Gen Set Gary Generators & Electric Motors General Discussion 6 03-30-2002 05:36:15 PM
