More Western Electric Light Plant
this thread has 1 replies and has been viewed 484 times
Old 10-21-2018, 06:50:21 PM
Mike Schweikert's Avatar
Images: 26
Default More Western Electric Light Plant
So still plugging away on this plant #1 of 2.
Got a hoist and lifted the engine case off the base to better eval the gas tank and clean it.
I was able to get the hangers out intact, cant say the same about the tank. Swiss cheese comes to mind. I am really glad I did this, it would have leaked everywhere.....
Its gonna need either a ton of solder, or I will have to get a new one made.
I suspect the filler neck is brass as well as the pipe bung for the gas line conduit.
Figured folk would be curious as to "what's underneath it"
ID:	321259   Click image for larger version
ID:	321258   Click image for larger version
Mike Schweikert
Jamison PA
The Following 2 Users Say Thank You to Mike Schweikert For This Post:
Old 10-22-2018, 04:57:25 PM
Thumbs up Re: More Western Electric Light Plant
Contact John Wonat - I believe a Stak sponsor. You can send him your old tank, and he will build you a new one. he will transfer your fittings to the new tank. he does a great job, and you can't beat the service!!
Western Electric / Fuller & Johnson 15B Lighting Plant Parts Needed MBreen254 Generators & Electric Motors General Discussion 8 09-09-2017 10:26:39 AM
Fuller and Johnson Lighting plant/ Western electric choofer Smokstak Down Under 2 12-29-2014 03:35:22 AM
Matador electric light plant riverratpeter Generators & Electric Motors General Discussion 1 04-11-2012 11:59:49 AM
Need Info: Western Electric 32V light plant Bob Painter Delco and other Low Voltage DC Light Plants 20 11-12-2008 09:38:25 AM
Old Western Electric Power and Light Set Nazrat Hit & Miss Gas Engine Discussion 4 08-18-2007 08:04:37 AM
