Delco Battery Shipping Crate
this thread has 6 replies and has been viewed 599 times
Old 11-09-2018, 10:02:35 PM
joder joder is offline
Default Delco Battery Shipping Crate
Just picked this up and was curious if anyone has or has seen another one of these.
ID:	322489   Click image for larger version
ID:	322488   Click image for larger version
Old 11-09-2018, 10:43:03 PM
Zephyr7 Zephyr7 is offline
Default Re: Delco battery shipping crate
It looks awfully nice to be a shipping crate. I suspect it’s actually a battery rack intended to hold the batteries together while they’re in service. Four “battery holes”, could be an 8v string (2v cells), 16v string (4v batteries), 24v or 32v string (with 6v or 8v batteries). I know those last two were common voltages.
Lindsey publications used to have a reprint of an old book about batteries for rural lighting and vehicles. I have a copy around somewhere, not sure if I can find it though. I wouldn’t be surprised if that book might have this in one of the pictures.
Bill
Old 11-09-2018, 11:51:32 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
One of the wife's relatives was really into generating his own power, had an expensive wind generator and had an enormous supply of those glass jar batteries, he would even weld with the battery pack. he had a few of those boxes to keep the battery banks in. After the wind felled his home made tower, he got a couple of old Delco power units to charge the batteries, later he tried to set up a steam generator, but never got it going. Good thing as he would have killed someone with that junk boiler setup.
Old 11-10-2018, 10:08:41 AM
Junkologist's Avatar
Images: 160
I have one, but don’t have any photos of it right now. Most of these crates have the top coming to a point so they could never be placed upside down. Looks like the points on yours have been cut off. Here’s a photo of one just like mine.
SmokStak member #146
Old 11-10-2018, 03:05:44 PM
Exclamation Re: Delco battery shipping crate
Most Delco lite plants were 32 VDC. The batteries were set in racks to keep them off concrete floors, and prevent the glass battery cases from being chipped or broken. Nice find!
Old 11-12-2018, 05:26:15 PM
Dale Burkman Dale Burkman is offline
These crates were used to ship the batteries in.
The Following User Says Thank You to Dale Burkman For This Post:
Old 11-12-2018, 05:31:49 PM
Thanks to all - now it looks like I need a Delco in my collection.
IHC LA Shipping Crate ccalkins Hit & Miss Gas Engine Discussion 0 06-19-2016 11:09:20 AM
Delco 8BW3 Battery charging generator M Schwab Generators & Electric Motors General Discussion 2 11-08-2013 09:39:40 PM
delco light plant 850 shipping weight mrtowmanalan Delco and other Low Voltage DC Light Plants 0 09-05-2011 09:18:16 PM
Delco-lite battery voltage??? David M. Lyon Generators & Electric Motors General Discussion 4 05-11-2005 05:25:11 PM
Need good photo of Delco battery rack kd4hsh Generators & Electric Motors General Discussion 0 10-15-2004 01:03:10 PM
