Back to the Western Electric
this thread has 4 replies and has been viewed 479 times
Old 12-16-2018, 03:28:25 PM
Mike Schweikert's Avatar
Images: 26
Default Back to the Western Electric
So a little more progress. A NEW gas tank for it and NEW pipes for the control board. I did try hand rewinding the resistance tube for the charging circuit and its just not going well. I imagine if I made up a winder and fixture, it could be done, but its not worth the hassle right now.
Soooo I looked into wirewound resistor tube to replace it. It is two section originally, (two separate resistance pieces on one tube with wires to different sections). Now the reason for that was the smaller ohm winding would be for normal battery charging, and the larger one was for overcharge mode, when the lever was flipped over. I am never going to use that, so am sticking to just one resistor for the normal charging mode. There is no specifications at all in the book on the ohms. In a prior post I counted the turns and measured the ohms in one turn of wire. I am getting about 3 ohms per turn, and its 12-13 turns. Its about 50 ohm. I got a 50 ohm 100 watt sliding tapped resistor to use. My question is at 40 volts max, it will allow .8 amps at 32 watts. Does that mean that the total output despite the amp meter on the board, will only charge the bank at .8 amps? At 32 volts the charge rate I think would be .6 amps.
Thank you!
MIke
ID:	324552   Click image for larger version
ID:	324551   Click image for larger version
Mike Schweikert
Jamison PA
The Following User Says Thank You to Mike Schweikert For This Post:
Old 12-16-2018, 04:38:45 PM
Default Re: Back to the Western Electric
Without completely dissecting the schematic, I believe that resistor only passes shunt field current, not the battery charging current itself, so shouldn't have much current flow through it.
Old 12-16-2018, 09:03:05 PM
Dale Burkman Dale Burkman is offline
It's only the field current that flows through that resistor.
The Following User Says Thank You to Dale Burkman For This Post:
Old 12-18-2018, 07:14:43 PM
Images: 26
I don't get what they were trying to do. Regulate the field to keep output steady, or to keep the charging relay from bouncing off and on from voltage sags or spikes??
Mike Schweikert
Jamison PA
Old 12-18-2018, 07:54:44 PM
The variable resistor regulates the field which controls the output voltage.
Me 1 Western Electric 0 Mike Schweikert Delco and other Low Voltage DC Light Plants 3 09-08-2018 04:01:30 PM
Need help, Western Electric Gen Joe Musser Generators & Electric Motors General Discussion 3 01-03-2005 06:12:42 PM
8B Western Electric Phil Robinson Generators & Electric Motors General Discussion 0 08-18-2004 09:41:49 AM
Western Electric Gen Set Gary Generators & Electric Motors General Discussion 6 03-30-2002 05:36:15 PM
Western Electric/Thanksgiving Gus Simms Generators & Electric Motors General Discussion 0 11-23-2000 10:44:01 AM
