My thirty dollar saw
this thread has 4 replies and has been viewed 2764 times
Old 05-25-2012, 05:09:35 PM
EricR EricR is offline
Default My thirty dollar saw
Yeah I know it ain't too vintage, but I think I did good on this one! Not one bit of plastic on it either.
http://www.youtube.com/watch?v=tM9G2lupKRY
The Following 2 Users Say Thank You to EricR For This Post:
Old 05-26-2012, 12:09:10 AM
Email NOT Working
Default Re: My thirty dollar saw
No Plastic?
Good for you!
I have a shotgun with a plastic trigger guard. It irks me to no end.
I've never had a Poulan, but have heard they're good saws.
Enjoy!
Kevin
Old 05-26-2012, 10:36:57 AM
Never had a Poulin saw myself but know a fellow who had several. For $30 definitely a good deal. You might want to give the chain a little more sharpening though!
Bill
Old 05-26-2012, 11:07:24 AM
gvasale gvasale is offline
Befor you say too much, check and see if the fuel lines were replaced. I got 2 of the same off ebay, and fuel lines were the issue. You can cut up a largish Briggs foam element for your new one. There are some spots inside the air cleaner shroud that have foam filter material in there too. I need a new bar for mine at this time, but in a pinch I used a bar from an old Wen electric, drilling a proper oil hole and cutting away the closed back for a little more adjustment. The only other small saw I liked just a bit more was the micro saw from Sears, which was also a Poulin. It weighs a couple of pounds less, but alas, it needs a coil (I know, good luck finding that.)
Old 06-06-2012, 11:07:14 PM
Exclamation Re: My thirty dollar saw
Doesn't sound too bad. You do have it set too lean though. Tune to run best at high speed, then back off mixture until saw begins to double stroke, no load. The way you have it now, if you keep loading it heavily, you will burn out the piston and cylinder. Chain sharpenning will greatly enhance cutting ability! You certainly got a good deal for $30! Nice find
Late Emerson Brantingham Big 4 Thirty Bruce Flatmoe Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 172 05-28-2018 11:02:13 PM
What Some People Will Do For A Dollar... wheelhorseman Garden Tractors and Mowers 9 04-20-2012 02:48:45 PM
Caterpillar Thirty yard mule Brad Kelley Dozers and Crawlers 11 09-23-2010 12:58:02 PM
1928 Caterpillar thirty project Reeves13hp Dozers and Crawlers 15 06-16-2010 10:31:38 AM
CP GW One Thirty Welder Info needed Don Smith Welding Shop 1 04-03-2008 11:31:13 AM
