Only starts when flooded?
this thread has 5 replies and has been viewed 1550 times
Old 11-28-2003, 09:09:21 PM
mbh
Default Only starts when flooded?
Recently restored 1.5HP Hercules E & only way to start it is to flood it. That is, fully choked until gas runs out of mixer then when it fires & black smoke comes out then open the choke. But if we open the choke too far it'll immediately die until fully choked again. Once it's hot we can cut back the choke a bit.
Any ideas on why this might be? Thanks in advance.
-Mike
Gurley, Alabama
Old 11-28-2003, 09:29:43 PM
Chip Watford
Default Re: Only starts when flooded?
Mike, It sounds as if it's starving for gas and the only way it can pull enough gas to run is with the choke closed.Be sure the check valve is not stuck and that it also seals off to prevent gas from draining back to the tank.Check that the fuel pipe and line[and strainer if it still has one ] is not stopped up.Also be sure the intake valve spring has the correct tension and that the valve works freely.Hope this may be of some help.Chip
Old 11-28-2003, 10:16:46 PM
mbh
The check valve is definately free. But, the gas line has to be tightened pretty good to clamp the tube & may well be the issue.
Thanks for the advice.
-Mike
Gurley, Alabama
Old 11-28-2003, 10:48:43 PM
Rich Martz
I've got the same problem with a 5 hp Economy. It will only run fully choked with gas dripping out of the carb. It runs all day but never gets hot. Is this normal for these engines? Thanks
Old 11-28-2003, 11:11:42 PM
Rick Strobel
Whether it drouls or not, can depend on the governed speed. Economy's are noted for this. Try running a little faster and see if it dries up some. RickinMt.
Old 11-29-2003, 09:52:13 PM
Glenn Karch
Hercules built hit and miss engines usually need to be choked until liquid gas is present in the mixer. If an engine is tuned and set to run at rated speed, generally no choking is needed after starting except sometimes to get the engine warmed up. When you slow them down, it is another matter and they aften need choking, blow black smoke and drool.
Flooded.... 8C3/752 Mobile Mechanic Delco and other Low Voltage DC Light Plants 0 11-27-2018 09:09:12 PM
Onan 5000 in RV, Starts then Dies about 15 times, then Starts and Runs Perfect F800kris Onan Generators 17 03-22-2018 09:13:08 AM
Did the C.P.M. grounds get flooded yesterday? Contaucreek Hit & Miss Gas Engine Discussion 2 06-05-2016 10:33:43 AM
Flooded Engines Steve Kreiner Hit & Miss Gas Engine Discussion 9 04-30-2011 01:21:37 PM
