Early Briggs WI with IBP style carb ?
this thread has 12 replies and has been viewed 2153 times
Old 03-19-2013, 10:27:51 PM
Nathan Grissom's Avatar
Nathan Grissom Nathan Grissom is offline
Default Early Briggs WI with IBP style carb ?
I bought this engine recently and was wondering if the WI's were ever offered with this carb or if someone just put this engine together from parts. Any ideas ?
Thanks,
Nathan
www.nathansoldiron.blogspot.com
Old 03-19-2013, 10:44:35 PM
Bowtiebutler956 Bowtiebutler956 is offline
Default Re: Early Briggs WI with IBP style carb ?
I just checked the book, and yes this was available on the WI. Its part no. was 89282. Very nice looking WI !!!
Matt
Old 03-19-2013, 11:54:02 PM
Cool thanks.
Nathan
Old 03-20-2013, 02:09:59 PM
Bigjoedo's Avatar
Bigjoedo Bigjoedo is offline
I agree with bowtiebutler956 definitely available on the WI. Very unique. Nice engine, post a video when you get it running.
Bigjoedo
Old 03-20-2013, 05:03:36 PM
gambitace71 gambitace71 is offline
hi,the early WI did not have the glass bowl.the early model I had the glass bowl.the carbs are the same except for the top.the early model A carb top is the same.go to gravely guy.com.there is an early moel I and an early model WI to compare.also check the pictures if the early model A to comper carb tops.thanks
Old 03-20-2013, 07:01:18 PM
grega's Avatar
grega grega is offline
GamBitace71 is right. Also all the float carb WIs iv ever seen had the larger tank with the brass shutoff. All said I beleive your engine is a model I with a WI tag
-Greg
"There only origionial once"
Old 03-20-2013, 07:24:56 PM
bart price bart price is offline
I don't think its a model I but carb don't belong one a WI.
Old 03-20-2013, 07:52:56 PM
grega's Avatar
Bart, why don't you think it's an I? If it dousnt have the 4 bolt pto i I'd say wi but without knowing from the pic is say model I.
-Greg
Old 03-20-2013, 07:58:44 PM
Greg I cant see the pto side. That's why I said that
Old 03-21-2013, 07:31:00 PM
Dengine Dengine is offline
Nice engine! Looks like a WI to me, i can see the pivot pin on the pto side meaning it probobly doesn't have the 4 bolt pto. The Briggs type N carb. on your engine was I believe used on some early model WI's. The way the fuel line is bent it looks like it was for a type GF carb. they didn't have the sediment bowl fuel filter on them as mentioned. It could be the carb. and or the tank was possibly changed on your engine at some point.I don't have a float carb. WI but the ones I recall seeing had the larger tank. I am curious to know the type number on the tag. Just my thoughts, Den
Old 03-23-2013, 10:07:13 PM
It is a WI block with no pto bolt holes. Here is a couple more pics.
Nathan Grissom
ID:	161117   Click image for larger version
Old 03-25-2013, 02:17:18 PM
Jim Metzger Jim Metzger is offline
Actually, I have three of them. Two with the one gallon gas tank and one with a two quart gas tank, all lever start on the PTO side.
Old 03-25-2013, 07:28:16 PM
I think the top of the carb has gotten changed at some point because there is a support bracket underneath the carb that looks original.. I think these carbs are neat. I have one on an IBP and it runs great.
Nathan Grissom
"Torpedo" Style Briggs Gas Tank Info On Early Toro Starlawn Reel Mowers Austen Small Air Cooled Gasoline Engines 8 10-14-2012 09:37:08 AM
Early 3 digit first production Briggs R2 Carb Dennis Wyatt Small Air Cooled Gasoline Engines 11 04-27-2012 09:17:20 PM
Briggs FH early Brass Carb. Throttle repair (revisited) Sky Small Air Cooled Gasoline Engines 14 11-06-2008 10:41:55 PM
Early Style Steam Elbows Dusty Hit & Miss Gas Engine Discussion 6 11-06-2008 12:06:08 PM
CARB PARTS FOR AN EARLY STYLE WATERLOO Aaron Abey Antique Engine Archives 0 08-08-2003 09:48:10 AM
