Genco help
this thread has 3 replies and has been viewed 1336 times
Old 07-05-2013, 11:41:30 PM
GarysToys GarysToys is offline
Default Genco help
I picked up a 4hp Genco engine and generator a while back. Unfortunately,
when to machine was removed from service they simply cut all the wires about
4 inches above the generator. The electrical box must have been discarded
because it was nowhere to be found.
The engine and generator are free and turn easily. I would like to set up a simple display with some lights, batteries, and volt meter. However, I cannot find a wiring diagram showing which wire on top of the generator should be connected where to connect the batteries for starting, the 32 VDC output, and other connections.
Does anyone have a wiring diagram or possibly another machine where the wires can be traced properly? I can send pictures of what I have and the wires exiting the generator.
Old 07-06-2013, 02:07:16 AM
Doug Tallman Doug Tallman is offline
Default Re: Genco help
There is a Genco manual here.
http://www.oldengine.org/members/frank/genco.htm
Old 07-06-2013, 09:54:46 PM
Doug
Thank you for all the material on the Genco. This should really help.
Do you have one with the control box?
Old 07-07-2013, 05:33:20 PM
Dale Burkman Dale Burkman is offline
Send me your E-mail address I will send you a diagram. Dale Burkman
Genco Light Plant Joe B Delco and other Low Voltage DC Light Plants 4 01-28-2009 10:17:44 AM
Genco Light RIRR Generators & Electric Motors General Discussion 4 03-30-2005 10:53:32 PM
genco Tim Generators & Electric Motors General Discussion 6 02-10-2004 10:26:14 PM
Genco DANIEL DORECE Generators & Electric Motors General Discussion 3 02-08-2003 09:03:49 AM
genco-light ralph golightly Generators & Electric Motors General Discussion 2 05-31-2001 03:17:14 PM
