Fairbanks Morse light plant
this thread has 13 replies and has been viewed 2639 times
Old 02-19-2014, 11:00:25 AM
Geist Geist is offline
Default Fairbanks Morse light plant
does anybody know where I can get some light bulbs for my 1920 Fairbanks and morse light plant? I think it is a 32 or a 36volt light plant
Randy
Old 02-19-2014, 03:21:11 PM
David M. Lyon's Avatar
Images: 32
Default Re: fairbanks and morse light plant
I couldn't locate any 32 volt bulbs so I bought three 12 volt drop cord bulbs at the local electrical supply house and wired them in series. They burn just a little dimmer than the 32 volt bulbs but it's really not noticeable. Just be sure you wire them end to end in series to imitate one 36 volt bulb.
The Following User Says Thank You to David M. Lyon For This Post:
Old 02-19-2014, 04:20:11 PM
grant michigan grant michigan is offline
The tag on F/M light plant is 36 volts at full capacity. I also would like to find 36 volt bulbs.
Grant Michigan
The Following User Says Thank You to grant michigan For This Post:
Old 02-19-2014, 05:20:58 PM
Grant Michigan
You might check with the railroad guys. The steam locomotive dynamos were 32-36 volt , I think.
Kirk
The Following User Says Thank You to Kirk Taylor For This Post:
Old 02-19-2014, 06:31:21 PM
Kirk
I heard that but how do I get ahold of them? I have been trying but with no luck. Do you know of a way to contacting them?
Randy
Old 02-19-2014, 06:34:06 PM
Exclamation Re: Fairbanks Morse light plant
The F/M system is charging at 36 volts but uses 32 volt accessories. The overvoltage is for charging batteries. You can hook up 36 volts in batteries, but they will be undercharged in service, due to internal resistance. You can get 8 volt tractor batteries (you need 4) at Tractor Supply stores.
If you can get incandescant bulbe, clear 200 watt bulbs will light up pretty good on 32 volts. An electrical supply can order 32 volt bulbs for you, but they won't be cheap. 32 VDC is used in maritime (ships) and railroads. The bulbs are out there, but you have to look for them. Look on EBay or Craigs list, and place an ad here on the Stak in the Enginads forum.
Old 02-19-2014, 06:46:20 PM
Default Re: Fairbanks Morse light plant
[QUOTE=Andrew Mackey;1015398]The F/M system is charging at 36 volts but uses 32 volt accessories. The overvoltage is for charging batteries. You can hook up 36 volts in batteries, but they will be undercharged in service, due to internal resistance. You can get 8 volt tractor batteries (you need 4) at Tractor Supply stores.
Andrew[/QUOT
When you say 200 watt bulbs is that 110 volts, or 32 volts?
Randy
Old 02-19-2014, 07:11:41 PM
200 Watt 110 volt bulbs. Not made for 32 volt, but will work in a pinch, and are a lot cheaper than the 32s. They will be about as bright as a 60 Watt 32 volt bulb. You can get 32s in 25, 40, 60, 75, 100 and 250 watts. I bought a box of 24 Phillips 250 watt 32 VDC bulbs in 1986 - cost me $13.60 EACH, back then! Now days??? They looked like regular bulbs, but were used in locomotive headlamps! Bright as the dickens, loaded the light plant pretty well, and lit up the model building end of Jacktown's display area like daylight!
Old 02-20-2014, 07:34:19 AM
loggerhogger loggerhogger is offline
Try a marine supply house. A few years ago we bought a bunch of locomotive headlight bulbs at an old marine hardware store. Turns out that they are used in the large spotlights on tugboats.
The Following User Says Thank You to loggerhogger For This Post:
Old 02-20-2014, 10:12:34 AM
Hal Rosenquist Hal Rosenquist is offline
Images: 12
Hi Geist, check the link below, they have 32 volt bubs listed by Anchor 7.26 ea pkg of 2 check it out. Hal
http://www.jamestowndistributors.com...t.do?pid=11744
The Following 2 Users Say Thank You to Hal Rosenquist For This Post:
Old 02-20-2014, 10:46:57 AM
Originally Posted by Hal Rosenquist View Post
Hi Geist, check the link below, they have 32 volt bubs listed by Anchor 7.26 ea check it out. Hal
That's actually not a bad price......unless you needed a couple hundred of 'em.
Kirk
Old 02-20-2014, 12:43:18 PM
Originally Posted by Geist View Post
Does anybody know where I can get some light bulbs for my 1920 Fairbanks Morse light plant? I think it is a 32 or a 36volt light plant
Randy
Even Amazon.com has them:
http://www.amazon.com/General-05032-.../dp/B0085UW1U4
Kirk
The Following 3 Users Say Thank You to Kirk Taylor For This Post:
Old 02-20-2014, 08:35:06 PM
Chris Props Chris Props is offline
http://www.1000bulbs.com/search/?filter[category]=1930&filter[attribute_voltage]=34
---------- Post added at 07:35 PM ---------- Previous post was at 07:33 PM ----------
That first link didn't show up right. Try this one. http://www.1000bulbs.com/search/?filter[category]=1930&filter[attribute_voltage]=34
The Following 3 Users Say Thank You to Chris Props For This Post:
Old 02-20-2014, 09:45:44 PM
Thumbs up Re: Fairbanks Morse light plant
Thanks for all of your help, I knew you guys could help me
Randy
Fairbanks Morse Three Home Light Plant D L Wertz Generators & Electric Motors General Discussion 9 01-03-2013 03:41:37 PM
My Fairbanks Morse ZC light plant engine alphahercules Antique Engine Photos 17 09-01-2008 07:20:04 PM
Fairbanks,Morse light plant Clint Querry Generators & Electric Motors General Discussion 1 01-22-2004 11:42:30 PM
Fairbanks morse light plant Frank Y Generators & Electric Motors General Discussion 1 10-23-2002 01:00:26 PM
Fairbanks Morse Home Light Plant Keith Generators & Electric Motors General Discussion 2 11-19-2001 04:04:26 PM
