What happens if you have a blown rotating diode
this thread has 6 replies and has been viewed 1996 times
Old 07-18-2015, 06:27:16 PM
BigBlockChev's Avatar
Default What happens if you have a blown rotating diode
I am about to dig into my DKC
http://www.smokstak.com/forum/showthread.php?t=147568
to diagnose the low (56V) output, this happens even at no load. It occurred to me that it might be a dead rotating diode (or even two). I know when you blow a diode in an automotive alternator it reduces the output but does not completely eliminate charging. Would this show up as a reduction in power output rather than in voltage. I am guessing that the VR would drive the output to meet the voltage setpoint regardless of load. I am also aware that if one diode is blown it takes that phase out so it would be a 1/3 reduction. Has anyone experienced this before with similar symptoms. I am more curious than anything else , I still expect to find a faulty voltage reg. Cheers Dan
Every machine is a smoke machine if you operate it wrong enough
The Feynman method , teach it to a kid , then you understand it.
Old 07-18-2015, 09:40:34 PM
ArodaPowerCo ArodaPowerCo is offline
Default Re: What happens if you have a blown rotating diode
I have experienced blown diodes twice, but neither were Onans. One had only a few volts of output, another had zero output. Both had been overloaded with high surge loads and the breakers were also ruined.
The Following User Says Thank You to ArodaPowerCo For This Post:
Old 07-18-2015, 10:04:43 PM
The voltage tends to dip badly under load. Easy to check them once you get there, tho. check the windings, since you have to disconnect one leg of the diode to check them, might as well get the windings done as well.
The Following 2 Users Say Thank You to pegasuspinto For This Post:
Old 07-18-2015, 10:58:39 PM
It does not sound like a high order possibility in that case. I will probably attack the voltage reg first since I don't like to mess with the rotating wiring if it is not suspect, too much chance of difficulty getting things back together without breaking something or screwing it up. Cheers Dan
Old 07-19-2015, 10:55:09 AM
Diodes can open or short which might present different symptoms, but I've never seen more than just a few volts resulting from one open diode. If you have already checked all the stator windings and connections, it's worth checking the diodes and rotor windings if they are easy to get at. Have you tried re-configuring it for something different? I haven't had the opportunity to deal with a -18 head, but I have read where earlier DK units had some stator issues (yours is a later one)
Do you have access to an oscilloscope? Curious to know what the output actually looks like.
Old 07-19-2015, 03:11:35 PM
Gunny Gunny is offline
Depends. If you have a shorted diode, you'll not have any output. 1 open and it might do fine except near full load and that will depend on the type of load. A resistive load, probably not notice it, a reactive load and you will.
2 bad diodes and it probably not work at all, you will probably have residual voltage and the regulator will be working its donkey off trying to get the voltage to where it needs to be and will eventually kill the regulator or trip the exciter breaker.
Measure excitation voltage, shou dbe around 12VDC at no load and the expected output. If a lot higher, like 20VDC (YD and such), look for an open diode.
An open diode has no effect on one phase making more voltage than the other. Its all about how strong the rotor gets magnetized and in turn the output voltage level.
If I were you, measure excitation voltage and go from there. With 56 VAC output (about half of nominal) I'd suspect that you have a regulator issue. Measure at the regulator F1 and F2 (or X and XX). Going to guess and predict it will be 0 or close to it. If so, disconnect the regulator (F1 and F2) and apply 12VDC from the battery is OK withe the engine running at 1800 rpm. Voltage should hop right up to pretty close to nominal. If that happens, be sure that the regulator sense and power wiring is good, can leave the battery powering the excitation while you are doing that. If the regulator is bad, then call Flight Systems and get a new one. Have your old one rebuilt by them and keep a spare on the shelf.
The Following User Says Thank You to Gunny For This Post:
Old 07-19-2015, 08:36:59 PM
Conclusion field exciter coil open circuited. I may have misread the decimal my volt meter , I was expecting 56V cause the guy said it put out 50ish volts but it was actually 5.6v. When I checked the field resistance it was open circuited. I pulled the coil out and went over it with a 10X magnifier and found 2 spots where green corrosion was present. I was able to pick the wires out of the bundle and solder in a repair then heatshrink over the solder joint. Back to 13 ohms , put it back in and fired it up , got 230V leg to leg 116V to neutral, so I am happy. Incidentally I noticed that the exciter coil seems to interchange with a J series coil that I had lying around so that is useful information. I like interchangability. Cheers Dan
Name:	exciter break1.jpg
ID:	230114   Click image for larger version
Name:	exciter break 2.jpg
ID:	230115   Click image for larger version
ID:	230116   Click image for larger version
Name:	j series coil in DKC endbell.jpg
Rotating Throttle Repair? GreasyIron Steam Stationary Engines, Traction Engines 22 09-23-2014 11:27:59 AM
Wisconsin VF4 rotating assembly ? GrumpyBobby Wisconsin Engines 4 05-03-2013 09:26:30 AM
Help need MEP 016b rotating diode part number geobruton Military MEP and Aircraft Gen-Sets 3 09-01-2010 08:22:39 AM
MEP-16A Rotating Diode? K D Redd Military MEP and Aircraft Gen-Sets 3 08-19-2008 12:19:28 AM
