Associated Engine early style igniter
this thread has 6 replies and has been viewed 1439 times
Old 08-12-2015, 10:31:57 PM
PrattDave PrattDave is offline
Default Associated Engine early style igniter
Can someone tell me if the sponsor of the Associated Website is still active - I have been trying to contact Keith at Amanco45 with no results.
Thanks,
Dave Pratt
Bardstown, KY
Old 08-13-2015, 08:20:04 AM
DavidRaines DavidRaines is offline
Default Re: Associated Engine Website
Don't think he is active anymore. What do you need?
Dave
Old 08-13-2015, 08:27:27 PM
Dave, thanks for the reply. I have a 1 3/4 HP aircooled Associated with the early style igniter. I need to know how to set it up, it is currently running with points open and a battery/coil. What I don't know is how much gap there should be when the igniter is at rest, and any other adjustments that might be critical to good operation.
Any advice or information will be greatly appreciated.
Dave Pratt
Bardstown, KY
The Following User Says Thank You to PrattDave For This Post:
Old 08-13-2015, 10:16:13 PM
Rich Mueller Sr's Avatar
Rich Mueller Sr Rich Mueller Sr is offline
You want to run the points open with a battery and coil, the gap should be about 16th " ,more or less, depending on how wore. The bolt on the anvil needs to be loosened on the shaft to do this. There should be a spring about the size of a ball point pen spring to a pole on front of the igniter to a little tit on anvil on arm by the holt. The very early ones have no springs to hold them open, those you have to balance them, yea a hassle. The back post is to hold point closed to run on mag with a spring. On straight trips the trip part has to be about 25-30% angle, the goose necks are straight up and down when looked at from straight on...
---------- Post added at 09:16 PM ---------- Previous post was at 09:03 PM ----------
A better forum for more questions on it would be in the antique gas engine discusion also..
United Gasoline Engine Registry www.augermo.com
The Following 2 Users Say Thank You to Rich Mueller Sr For This Post:
Old 08-14-2015, 07:16:00 AM
Rich, this is exactly what I need. Thanks for your help. Dave Pratt
Old 08-14-2015, 12:10:13 PM
Default Re: Associated Engine early style igniter
To make them run and start really good you need a Associated ball type check valve that holds the gas back until engine disturbs the ball with vacum and lets gas flow. The closer you can get the valve to carb is better and tank just slightly higher than carb..
Old 08-15-2015, 07:54:09 PM
Terry Beasley's Avatar
Terry Beasley Terry Beasley is offline
Keiths site is still up. He posted a photo of my old style igniter on my 6 HP a few years back. I bought a spring assortment from Harbour freight and one of their springs was perfect to hold the points in place without the back stop used on the newer igniters.
http://www.webring.org/l/rd?ring=old...ageindex%2Ehtm
The Following User Says Thank You to Terry Beasley For This Post:
Early Style St.Mary's BuckeyeMan Hit & Miss Gas Engine Discussion 0 08-10-2015 03:44:16 PM
Early Briggs WI with IBP style carb ? Nathan Grissom Small Air Cooled Gasoline Engines 12 03-25-2013 07:28:16 PM
One More Engine Video early style 7 HP Field-Brundage engine Chris Epping Hit & Miss Gas Engine Discussion 6 09-28-2008 09:49:29 AM
Waterloo Boy, Early Style, Model Engine D. Dean Suhr Scale Model Engineering 2 10-30-2007 09:50:02 PM
Galloway 2 1/4 HP "Early Style" Engine Dave Mahan Hit & Miss Gas Engine Discussion 6 04-23-2007 11:33:21 AM
